Alarm flash no sound
W203
So my alarm works if i press the panic button or open the door from the inside while armed but it doesnt make any sound. The normal horn works but not the alarm one, I read online that it is fairly simple to do, by the front passenger tire as far as i remember? My question is what part do i search for on eBay and is there any after market alarm horns that will fit that will well sound better then the original one. I have a 2004 c230 sedan. Thanks!!
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
Just buy the original siren. Aftermarket sirens don't usually work.
Also you NEED A SECURITY TORX SET to remove the siren. The siren should be under the drivers side wheel well, beneath the covering (at least that's where it was when I replaced it on my CLK). If you can't remove the torx, then try to mount the horn somewhere else. I had to do that, and I found an ingenious spot under the fender.
