Sunroof Mercedes C230 coupe not opening
Mercedes C230
I have a c230 coupe from 2002, the sunroof won't open. I already tried syncing it. The sunpanel does work. I removed the panel that gives acces to the motor, but i only see one motor on the right side.
Is that normal? Are both the sunscreen and glass powered by 1 motor?
Because I've read some posts that said they had a second motor on the left for the actual glass to move.
I also pulled out fuse 9 in the trunk (put it back in ofc) and tried resyncing, after I ''resync'' that sunpanel stops working as well. Then I pull out fuse 9 and put it in again and it works again. But the actual sunroof never works.
As you can see on the attached picture it seems that my left motor was removed somehow?
