Replacing oil filter, lot of oil in housing? What's up with that?
Old 02-27-2015, 07:41 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Did an oil change recently and noticed the oil just seems to sit in the
oil filter housing and won't drain. I sucked out about 6 oz of oil to get to the bottom and inspect it.
Can't see anything obvious.
Anyone encounter this?
Something clogged? How to fix it? 35 is an idle valves & 26 is a bypass valves FYI
Old 02-28-2015, 07:05 PM
Super Moderator
samaritrey's Avatar
THE C350
I noticed the same thing on my w203 and w211 every time I change/d the oil so I doubt it is an issue.
Old 02-28-2015, 10:15 PM
phister's Avatar
06 C230 SS 6spd
Mine has the same thing when I change my oil as well. I think it's oil from the filter that drains out when you loosen the filter.
Old 03-02-2015, 06:56 PM
My oil seems very sludgy and I did 2000 miles ahead of time.
Well I do have >223K miles...so can't ***** too much.
Old 03-02-2015, 09:58 PM
Super Moderator
samaritrey's Avatar
THE C350
That isn't good do you think it could have some coolant/fuel contamination? What oil do you use?
Old 03-03-2015, 10:23 AM
phister's Avatar
06 C230 SS 6spd
Sounds like you got water or coolant in your oil. Is there any smoke coming out the exhaust?
Old 03-03-2015, 04:52 PM
Well the head gasket has been leaking for a long time, mostly out the side of the head.
But didn't seem worth it to replace the gasket, local mechanic wants $2500 plus.
A replacement engine can be had for less.
Old 03-03-2015, 05:11 PM
phister's Avatar
06 C230 SS 6spd
Sounds like a coolant leak. Surprised you haven't blown the head gasket yet and killed the engine.
Old 03-03-2015, 10:30 PM
Khan28's Avatar
2012 C300 Sport 4MATIC (current) 2006 C280 Elegance 4MATIC (sold)
It would probably be a good thing to get the head gasket looked after. After all burning coolant is one thing but it will find it's way into the oil as well. I remember seeing a YouTube video by Scotty Kilmer talking about Steel Seal which you pour into the coolant and it supposedly seals small head gasket leaks. Whether it's a gimmick or the real deal I'm not sure. Not sure if I'd try that in a Benz either even though you're at such a high mileage. It's kind of like a badge of honor having 223k on a motor that's known to be a bit quirky.
Oh BTW when I change my oil I slightly open the oil filter cap about halfway then I jack up the car and drain it from underneath. At that point the oil filter housing is pretty dry. It's kind of like when you open the back of a jerry can, it allows for better drainage.
Quick Reply: Replacing oil filter, lot of oil in housing? What's up with that?
