becker standard cd player audio 10 2003 w203 after replacments with aux?
Old 03-13-2015, 08:10 AM
triffer's Avatar
2003 c class coupe 220cdi
There is no way to fit aux to audio 10 cd player what other direct replacments are there that will fit 2003 c class sports coupe where i wont loose steering controls
are there or is it best to go aftermarket and get one fitted?
Old 03-25-2015, 07:32 PM
stewie28's Avatar
C180K Avantgard Estate with a Prins LPG system
Hi
I would go with an aftermarket unit with usb input and BT streaming as well as an AUX jack input.
I fitted an Alpine unit but JVC do some Good double din units with these features.
Figure on an additional £80+ for additional bits like facia panels and loom adapters.
steering wheel controls can be maintained with a control interface.
Sound quality is way beyond that of the unit fitted and shows the quality of the stock speakers.
can be installed yourself if you are quite handy and research the You tube videos on installation for the steps to take as it requires removing most of your centre console to fit the new unit.
It will bring you audio upto date and USB input with mp3 means you get the benefits of a big music library without a CD changer.
Old 03-26-2015, 04:13 AM
triffer's Avatar
Cheers for the info many thanks will look into it been using an fm transmitter but find the sound quality poor at best..
Quick Reply: becker standard cd player audio 10 2003 w203 after replacments with aux?
