* HOW TO REMOVE BROKEN SWAY BAR BOLT FROM SUB FRAME???
1 Post
2002 C230 Coupe
Yes, you'll need to center drill the broken bold and apply a screw extractor (aka ez out). Start by hosing it down with penetrating oil. Then use one of those extractor kits that starts with a left-hand twist drill, so you need to set your drill to reverse to drill into the broken bolt. Sometimes just that is enough to spin out the broken bolt. Then when you have enough of a hole to start the extractor, twist it in and pull the bolt. Work carefully - if you break the drill or extractor in your broken bolt, you'll need professional help.
2002 C230K, 2013 BMW 328, 2015 BMW X5
2004 C230 kompressor
The bolt broke off flush with the cradle. I left to pick up a client and a mechanic in my shop decided he would "help out" and tried using an EZ Out after he broke the bolt. Problem is, he drilled crooked and couldn't get it out. I don't know if I can re drill it straight or if trying would be a lost cause because the larger bit will stay in the same crooked line. It's really in there.
Super Moderator
Another thing to try would be using a small drill bit re drill it straight then step it up unit you can use the ezout. Lots of PB blaster for a few days should help as well.
Weld another bolt onto it, then back them both out. Before you do that and if the area can take heat, get it cherry red with a small tip on you Oxy/Act. When it cools back down it will shrink at a different rate than the frame and that should help pop it loose. Weld on a bolt and it should come on out. I've done this a bunch and it is really the best way. Bolt/screw extractors are only for when/if you can't weld.
1 Post
C230 COUPE 2003 M271
I found this out later when I was doing other suspension work, that my mechanic had drilled out one of the holes, maybe larger, and he attached the bushing to the sub frame with a bolt going through the hole and he put a lock nut and washer on the other side.
