C32 seats
1 Post
w219 CLS 320- Distronic and Keyless
C32 seats
hi Gents
Just a quick one, is it possible to swap my half electric seats for the c32 ones. I am also getting the door cards and controls as well.
Will I be able to get full functionality, heated and 9 way adjustment. Would I be able to get the memory function working?
My budget is about £500 and the seats are costing around £350 with door cards. Is it doable with this budget.
Thanks for all your help.
Zain
Zain
1 Post
Hi
Thanks for your reply.
Were you able to get the full electric adjustment working? What part numbers are needed?
Were you able to get the heated seats working? What part numbers are needed?
Thanks for your
Zain
Thanks for your
Zain
I am in the middle of doing a C32 seat swap. I was able to take out the modules from under the seats and trace some wires.
One goes to the fuse box in the trunk, some goes into the center console button's row. A bunch of ground wires, some are attached to the airbag censor also in the middle of the console.
One wire which I have no idea where it goes to is.. it goes to under the dash driver side. I lost it around the hand brake area. If anybody is able to pull up a wiring schematic, that would make it a lot easier for me to take my C32 apart.
