Loud Whining Sound Coming From Engine (2005 c230)
Old 06-25-2015, 06:25 PM
cwilson's Avatar
2005 c230
Arrow Loud Whining Sound Coming From Engine (2005 c230)
For quite some time now my 2005 c230 Kompressor has been making a loud whining sound when it runs. I mean people know when I get home from work because they can hear the car coming through the neighborhood.
Through the search feature here on the site it seems this is most likely related to a the a/c compressor or the a/c pully. I took the car into PepBoys since they are located next door to where I work, they seem to think it's the a/c compressor.
I wanted to see what others here might think, as they wanted 2500.00 to replace it. So I really wanted another option, as if it is the pully, that is much easier/cheaper to fix.
- The sound is steady, all the time, with a/c on or off.
- The a/c works fine, ice cold actually, cools the car fast
- The faster I go, the louder it seems to get.
If anyone else has run into this I would appreciate some feedback, don't want to drop 2500 unless I have to.
Here is a short Youtube video I made that lets you hear the whine sound.
Old 06-25-2015, 07:52 PM
Super Moderator
samaritrey's Avatar
THE C350
I would check PS fluid
Also remove belt and see if you can find any issues as well as start car to make sure the noise stops.
Old 06-29-2015, 10:02 PM
jrsmith_68's Avatar
2007 C350 2015 ML400 1968 Ford Mustang
I'm with Trey, that sounds like every bad PS pump I've ever heard.
Old 06-29-2015, 11:42 PM
billio's Avatar
2006 c230
answer
It.has.nothing.to do with air conditioning. Its your smog air pump
Old 06-30-2015, 01:48 PM
pcy
pcy's Avatar
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Secondary air pump only runs for a minute or so after starting the car. If the noise continues even after driving several minutes, then it can't be secondary air pump.
Old 07-02-2015, 12:25 AM
wvadam's Avatar
C230 COUPE 2003 M271
question: is there a possibility it could be the nose bearing in the supercharger? it is spinning at a much faster rpm
Quick Reply: Loud Whining Sound Coming From Engine (2005 c230)
