2002 c200 kompressor code p2038 G3/1 (o2 sensor downstream TWC)
hey guys im new in this forum, i had the above problems. what i already done is both o2 sensor changed, cat changed. after the code been erase but it keep coming back. any one have this experience pls help thx. the next step i could do is to change the cam sensor as well, hope it could be fine.
I am assuming that do do not use DAS Xentry to diagnose the lambda control problem---find someone who does and if he knows how to use the tool will pinpoint your problem in fifteen minutes!!---all else is stump the chump time!!!
PS--do not ask what is lambda control!!
final parts changed, camshaft adjuster magnet and supercharger oil top up. I found that the supercharger oil is empty. And the engine run well now, no more code.
