Codes P0016, P0017 failing emissions..what to do?
2007 C230
My car 2007 c230 has these two codes P0016 and P0017.
Just came back from Illinois Air Team emissions place and my car failed because of these codes..it's bull..
I have an OBDII to clear the codes, but they show up right after turning the car on.
What can I do? How can I get these codes off my car?
I cannot get these codes fixed because it's really not worth it, way too expensive.
Super Moderator
I assume you know what those codes are?
Sadly unless you can register your car somewhere where they don't do inspections you are kind of screwed.
I doubt it will be that long of an issue as eventually the car will either start running bad or have some more serious issue.
Without a VIN-----P0016 and P0017-could be either A or R right bank intake\exhaust camshaft position sensor------kinda easy to change out, but don't think of using used crap!!
2007 C230
I think it's the balance shaft
