Help urgent! c230 coupe 2003 missfire ,rough on idle
Old 07-28-2015, 09:14 PM
zesarz4's Avatar
c230 2003 coupe 1.8l automatic
Unhappy Help urgent! c230 coupe 2003 missfire ,rough on idle
Ok so i bought my c230 coupe 2003 in December it was good until 2 months ago, then i had lost of power ,rough idle and bad mpg this was what i did:
code was p0301 misfire cyl 1 (the rough idle is not all the time only when i put the car in park or neutral for 3-5 minutes)
- i change the plugs it worked for 1 day the next day it was the usual
-next i change coil 4 to 1 it worked for half a trip to my friends house
change 3 to 1 the same happen
- then i change the fuel injector work for half a day the mechanic said compression on cyl 1 =120 psi cyl 2=140 cyl 3 and 4=180 he said maybe the computer
-next i cleaned the contacts of 'twin camshaft sensors, computer, each coil,and the MAF" it worked for 10 min but only a little more power
-just now i change the 12$ hose worked for 5 min i accelerated hard to test and it was good then i stopped
right now i only have the check engine code for camshaft sensor and have almost no power struggling to get past 75 mph foot down getting like 14-17 mpg
i don't know what to do next any help will be appreciated ask anything, thank you
Edit- i forgot to say that acceleration has like a second of delay or "hesitate/sputter on acceleration problem" 170.000miles
Old 07-28-2015, 09:39 PM
Kazi04's Avatar
2004 C230 Kompressor Sport
I think you answered your own question... replace the camshaft sensor.
Old 07-28-2015, 10:38 PM
zesarz4's Avatar
Do you think that will be the answer ? when the rough idle started b the sensor was working it was like in the middle of the process when it stop working, and it had a plastic tie that i remove (last owner put it i think) will upload pictures tomorrow
Old 07-30-2015, 09:34 PM
zesarz4's Avatar
just change the sensors and catalytic converter and just seafoam the problem still there but no cel codes anymore, will do ecu reset tomorrow and oil change
Old 07-31-2015, 10:27 PM
zesarz4's Avatar
Any suggestion on what to do next? anyone?
Old 09-07-2015, 10:56 AM
YuVorona's Avatar
C240
Hi zesarz4,
Did you fix your issue ?
I have similar symptoms on my C240 2002: engine shaking on idling, not instant acceleration and not the best gas mileage
I changed all spark plugs and MAF
Camshaft was replaced last year
Did you have your catalytic converter replaced ?
Quick Reply: Help urgent! c230 coupe 2003 missfire ,rough on idle
