Another 'will it fit?'
Old 09-28-2015, 11:15 PM
Alswag's Avatar
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
I'm looking to replace my little coupey with a 1999 E55. The thing is, I'd like to keep the winter tires from my coupe and use them for the E55. The size of the rims is 17x7.5 ET35 (Or 37? dont remember). Wikipedia says that the E55 rims are 18x8 ET31 front, 18x9 ET35 rear, which makes me think that my non-staggered rims might fit.
What do you guys think? Has anyone tried this? I've searched the forum and google but got nothing. Thanks guys!
Old 09-29-2015, 02:05 AM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Should be fine since that generation of E (W210) can use W203/CL203 rims; thus wheel bolts as well. What is tire size of your 17"
Old 09-29-2015, 09:02 AM
Alswag's Avatar
The tires in question are 215/45.
The problem is I know that they fit the W210, but I don't know how well it will fit inside the fender because of the AMG brakes.
Speaking of, Sunny, want to buy a V6 with 140k?
Old 09-29-2015, 09:06 AM
illest's Avatar
4 matic
17s will fit over AMG brakes. With an offset of 37 you might need a small spacer to fit on a w210 e55.
Old 09-29-2015, 10:54 PM
My 4 cylinder has half your mileage,... but it's temping, not many V6 around,.. and yours is paprika like mine if I remember correctly.
W210 E55 AMG likely came standard with
front: 18x8 ET31 235/40R18
rear: 18x9 ET35 265/35R18
But could go as aggreesive as (without body mod)
front: 18x8.5 ET25 235/40R18
rear: 18x10 ET25 265/35R18
W210 could take:
front: 17x7.5 ET37 235/45R17
rear: 17x7.5 ET37 235/45R17 (non-staggered)
rear: 17x8.5 ET30 235/45R17 (staggered)
Your CL203 rims:
front: 17x7.5 ET37 225/45R17
rear: 17x7.5 ET37 225/45R17 (non-staggered)
rear: 17x8.5 ET30 245/40R17 (staggered)
rear: 17x8.5 ET34 245/40R17 (staggered)
Thus, I don't think you'll need any spacers with ET37
Your 215/24R17 tires are a bit on the skinny side,.. maybe a bit beneficial in snow since they're winter tires.
If your rims are AMG then the AMG brakes *should* clear,... MB? Post a photo of your rims. What is the model/part number of your MB/AMG rims? Usually imprinted on hub side of rim.
Old 09-30-2015, 04:24 PM
Alswag's Avatar
Mine's black actually. It even comes with a serviced transmission and replaced TCU connector.
Neat. So I'll keep these old crusty rims then.
They aren't Mercedes AMG rims, they're the coupe's original Alshain rims. So I'm somewhat concerned because I know the E55's brakes are freaking huge.
Old 09-30-2015, 11:44 PM
Your 17 x 7.5 ET37 Alshain (Evolution/C7) rims from CL203 will fit regular W210 E-series without issues, as will all Mercedes or AMG rims from CL203/W203 to W210 (remember all those AMG hammer rims that went the other way). But your 17" Mercedes Alshain rims likely will NOT fit E55 of that generation with AMG brakes because Alshain rims has weird ridges and rim spokes are generally flat. AMG rims have spokes that sticks outward more relative to lip and hub centre to allow more clearance room for bigger AMG brake caliper.
Generally, you could always go from Mercedes rim to AMG rims without issues,... but going from AMG rims to Mercedes rims,... you'll need to worry about AMG brake caliper clearance.
Best way to tell, would be a test fit,... but I really doubt it'll fit. illest is right, you'll likely need spacers to force them to fit but with these Alshain rims, you'll also have to worry about the those ridges too.
Quick Reply: Another 'will it fit?'
