Turn signal problem
Old 11-17-2015, 06:19 PM
jmoon13's Avatar
Mercedes-Benz C180
Exclamation Turn signal problem
Hey Guys,
Newbie here to the MB forum!
I am looking for an advice regarding my 2004 C180 Coupe. As a amateur i would appreciate some patience with my posts.
The problem is the left-hand turn signal. Even i push hard, it alway goes back to the centre position immediately and turn signal flashed only 3 times.
lamps looks fine as the hazard warning is perfectly working.
anyone can help me out???
Old 11-18-2015, 10:07 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
The turn signal combination switch is faulty---replace the switch!!
Old 11-19-2015, 08:56 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
This is rather interesting, as most people (myself included) have a problem when turning on the R blinker. In this situation, the weight of the stalk overcomes the "catch".
The switch can most likely be fixed mechanically - I would imagine it involves "adding" material to the catch so that it "sticks" better.
A new switch can do the trick, but I've already replaced mine under warranty, and this "new" one has also turned faulty. I'm starting to think it's better to DIY the repair. Anyone know if the turn signal part # has been updated?
Quick Reply: Turn signal problem
