Dash cam install 2003 c230 k
Old 04-25-2016, 11:34 AM
iosif62's Avatar
C 230 kompressor
Hi, I have a 2 door 2003 c230 and I am the first owner. For insurance purpose I just got a dash camera and trying to hard wire it. I do not know which fuse to attach the wires on the driver side fuse box so it will only work when the car is running. Please help and thank you in advance
Old 04-26-2016, 05:49 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to W203 forum...
Old 04-26-2016, 07:52 PM
Super Moderator
samaritrey's Avatar
THE C350
Cigarette lighter is always an easy target for 12 volt power that is switched.
Old 04-26-2016, 07:55 PM
VVF
VVF's Avatar
2005 C230K(sold), Mk7 Jetta
Is there a switched source to the rearview mirror in pre-facelift cars?
On facelifts there is a little bulb that is on when ignition is on. That would be a convenient place to tap into.
Old 04-27-2016, 05:40 PM
iosif62's Avatar
C 230 kompressor
I tried and hard wired it to the fuse box in the engine. A bit tricky but worked. I tested and found a fuse that was switched. Thank you all for your help.
Now I will do the same on my E320 and the 330i bmw.
Quick Reply: Dash cam install 2003 c230 k
