AntiFreeze Leaking????
2004 c240 4 matic
I have a mercedes benz c240 2004 4 matic anyone ever heard of anti freeze leaking? First the sensor went off saying i was low in anti freeze, later i filled it up 2 days later sensor was still going off, when i went to check i seen the liquid around the box and a hose, I didnt spell any first time around and now its empty, is the container no good or a hose?
MBworld Guru
If you see coolant around the reservoir, then it needs to be replace. One of two things (or both!) have occurred: The seal between the translucent and black sections has failed and/or the small nipple where the overflow hose attaches has cracked. A new one is under $100 and takes about 15 minutes to replace.
