Stuck Coolant Temp Sensor
2004 C320 4Matic Sedan
Tried replacing the sensor today and for some reason the sensor wont come out, like its stuck in the front of the engine. any ideas? the plastic broke off trying to remove it. thanks its the m112 engine for reference
Davis i think you will need to use brute force on it . Did you get the engine warm before you worked on the sensor . Can you get a good socket on it and a tube .Give it a tap with a hammer to brake the joint first ..
Davis the only thing holding it in there is the O ring Try twisting it around to break the seal .Get your pliers on it and try to move it, clock wise , and anti clock wise .
