Reverse Light Signal Wire
Old 09-26-2016, 03:18 PM
MBNewDude's Avatar
2003 C320
Hi all: I'm afraid a multi-apology may be due here as I'm a total noob to this stuff, and a total noob to using web forums as well. So if I've posted improperly, or asked a stupid question - apologies in advance. I hope you can overlook and help me
I am installing an aftermarket stereo (AVH-4200NEX) into my 2003 C320 with Bose. I think I have the install mostly figured out and done, including the fiber optic bypass. Here is where I'm stuck:
- I'm trying to install the reverse camera, had have already run the cable from the trunk to the dash, and connected the camera to the HUD.
- The HUD has a purple/white wire that is supposed to tap into the reverse signal wire to know when to switch to the backup camera.
- I have no earthly idea where to tap this purple/white wire in my dash/console, and I'd prefer not to have to run a new wire all the way back to the trunk to tap into the reverse light lead directly.
Any idea whether there is any wire up in the front of the car that I can tap into? Any help would be appreciated!
Old 10-01-2016, 12:16 AM
jrsmith_68's Avatar
2007 C350 2015 ML400 1968 Ford Mustang
There is no discrete signal in the dash/console area. The reverse signal is triggered over the CAN network and controlled by the rear SAM.
Old 10-02-2016, 07:26 PM
Petter Hanssen's Avatar
2005 C220 Sedan and 2005 A150
I ran a signal cable and tapped into the positive for the reverse bulb in the back. Has been working fine for 6 months
Quick Reply: Reverse Light Signal Wire
