can i remote windows with key ?
You should be able to, yes, by holding down the unlock button. Though there's a very good chance your reception sucks - do a search on RF and IR signals here, a lot of information, most bad. On the other hand, if that's the only current issue with your 2001, you're a lucky buckaroo.
A permanent fix is to get a mods4cars module, which I had and loved, but no one else ever got one. It was an awesome mod.
Point your key at the door and hold the lock or unlock button. holding the unlock button with the windows closed will open them. holding the lock button with the windows open will close the window. if it doesn't work it's because the sensor is bad. to get a new one you would need to purchase a new lock cylinder as they come together. or if you search around especially on benzworld you'll find the fix. problem is caused by a cold solder joint on the sensor. it can be fixed relatively easy. If you are not so inclined I have a couple of spares, I can do the fix, test it, and sell it to you for a reasonable price. PM me if you're interested.
