Abs SWAP with different number
Hello
Can I swap ABs module from w203 270CDI A 2035451632
with ABS from CLK w202 A 2025454732
Is there a difference in the wiring? I have STAR, but would it work?
Thanks!
Thanks!
I really doubt it. Maybe if you got one from a 209 that is based on the 203. a 202 one may be different tech. Then again I really have no clue.
I found this, But is it true ...?
ESP Hydraulic unit Mercedes A 003-431-82-12 A 202-545-47-32 Q06 Ate 10020402214 10094715123
ABS/ESP HYDRAULIC UNIT, WITH CONTROL UNIT
(!) Anti-lock Braking System (ABS)
(!) Electronic Stability Program (ESP)
ESP-Pump
P/No.: A 0034318212 / Ate 10.0204-0221.4
ECU / Steuergeraet ESP
P/No.: A 2025454732 / Ate 10.0947-1512.3
Vehicle applicability:
(1999-2000)
Mercedes-Benz C-Class (W202)
(202.018) C 180
(202.020) C 200
(202.024) C 230 KOMPRESSOR
(202.025) C 200 KOMPRESSOR
(202.128) C 250 TURBODIESEL
(202.133) C 220 CDI
(202.134) C 200 CDI
Mercedes-Benz C-Class Combi (S202)
(202.078) C 180
(202.080) C 200
(202.081) C 180
(202.082) C 200 KOMPRESSOR
(202.085) C 230 KOMPRESSOR
(202.087) C 200 KOMPRESSOR
(202.188) C 250 TURBODIESEL
(202.193) C 220 CDI
(202.194) C 200 CDI
Mercedes-Benz C-Class (W203)
(203.004) C 200 CDI
(203.006) C 220 CDI
(203.016) C 270 CDI
(203.035) C 180
(203.045) C 200 KOMPRESSOR
(203.061) C 240
(203.064) C 320
(203.065) C 32 AMG KOMPRESSOR
Mercedes-Benz C-Class Coupe (CL203)
(203.706) C 220 CDI
(203.735) C 180
(203.745) C 200 KOMPRESSOR
(203.747) C 230 KOMPRESSOR
Mercedes-Benz C-Class T-Model (S203)
(203.204) C 200 CDI
(203.206) C 220 CDI
(203.216) C 270 CDI
(203.235) C 180
(203.245) C 200 KOMPRESSOR
(203.261) C 240
(203.264) C 320
(203.265) C 32 AMG KOMPRESSOR
Mercedes-Benz CLK (C208/A208)
(208.335) CLK 200
(208.344) CLK 200 KOMPRESSOR
(208.345) CLK 200 KOMPRESSOR
(208.347) CLK 230 KOMPRESSOR
(208.348) CLK 230 KOMPRESSOR
(208.435) CLK 200
(208.444) CLK 200 KOMPRESSOR
(208.445) CLK 200 KOMPRESSOR
(208.447) CLK 230 KOMPRESSOR
(208.448) CLK 230 KOMPRESSOR
Mercedes-Benz SLK (R170)
(170.444) SLK 200 KOMPRESSOR
(170.449) SLK 230 KOMPRESSOR
(170.465) SLK 320
(170.466) SLK 32 AMG KOMPRESSOR
Reference numbers:
A0034318212, A-0034318212, A-003-431-8212, A-003-431-82-12, A 003 431 82 12
A0034318312, A-0034318312, A-003-431-8312, A-003-431-83-12, A 003 431 83 12
A0034319312, A-0034319312, A-003-431-9312, A-003-431-93-12, A 003 431 93 12
10020402214, 10-0204-0221-4, 10.0204-0221.4
10094715123, 10-0947-1512-3, 10.0947-1512.3
10020804682, 10-0208-0468-2, 10.0208-0468.2
DI 8005
HW 9942
SW 9942
BAS9918
3X3704
ESP-Pump
(1999-2000)
(202.018) C 180
(202.020) C 200
(202.133) C 220 CDI
(202.134) C 200 CDI
(202.078) C 180
(202.080) C 200
(202.081) C 180
(202.193) C 220 CDI
(202.194) C 200 CDI
(203.004) C 200 CDI
(203.006) C 220 CDI
(203.016) C 270 CDI
(203.035) C 180
(203.061) C 240
(203.064) C 320
(203.706) C 220 CDI
(203.735) C 180
(203.204) C 200 CDI
(203.206) C 220 CDI
(203.216) C 270 CDI
(203.235) C 180
(203.261) C 240
(203.264) C 320
(208.335) CLK 200
(208.435) CLK 200
(170.465) SLK 320
Reference numbers:
DI 8005
HW 9942
SW 9942
BAS9918
3X3704
