Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W203)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
Sponsored by : My Mercedes Parts
Click Here
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 21 votes, 4.81 average. Display Modes
Old 10-14-2002, 04:08 PM   #76
Re: 2003 Bi-Xenon for C230
Quote:
Originally posted by gab
is it available as an option to order?
has anyone checked whether it will fit 2002 cars?
has anyone checked if we can organise a group buy?
Yes it is available to order.
It will fit 2002 cars, but the 2002 cars do not have the proper wiring harness to make the auto-leveling system work. Some members have already installed them on their sedans. Do a search.
To remove this ad, register today or login if you already are registered!
Lynn is offline   Reply With Quote
Old 10-14-2002, 04:12 PM   #77
young's Avatar
Drives: C-Sportcoupe; 230K
afaik, no one w/ a coupe has done a retrofit of the bi-xenons.
__________________
<font face="arial narrow" size=2>Y O U N G </font>
young is offline   Reply With Quote
Old 10-14-2002, 06:27 PM   #78
Send a message via AIM to Mach430
Bi-Xenon Installation
Has anyone converted their halogen headlights to the new Bi-Xenons? What wiring harnesses/ballasts are necessary?
Mach430 is offline   Reply With Quote
Old 10-14-2002, 08:41 PM   #79
I think if you take out the whole Halogen assembly and replaced with the bi-xenon assembly, its just a plug and play job. The only thing that will happen is there'll be an error message because the computer did not program with xenon when it rolled out of factory. You have to get a service tech & reset the computer to "xenon present". One more thing....the auto leveling will not work.
Harris is offline   Reply With Quote
Old 10-14-2002, 09:11 PM   #80
Drives: C230K
Mach430
u got the new BI-XENON for c-coupe?
__________________
C230K
zhaoyi is offline   Reply With Quote
Old 10-14-2002, 09:56 PM   #81
I'm looking into both the coupe and sedan right now. I do not think it will be as easy as plug and play. Don't get me wrong, it shouldn't be difficult either. But from my experience with BMW's, you need to upgrade the ballasts and have the proper wiring harnesses in order to do so.
Old 10-14-2002, 10:42 PM   #82
Mike "bagwell" has done it. According to him, its a plug and play job. Maybe you can send him a PM or e-mail.
I changed mine from regular Xenon to bi-xenon, its also a plug and play for me.
Old 10-14-2002, 10:59 PM   #83
bajaiman's Avatar
Drives: 01 C200 Kompressor, 02 C32 AMG
Its as simple as plug and play.....but I can't adjust the headlight from inside the car anymore.....don't think this will effect US owners as you don't have the ability to adjust the headlight from inside the car in the first place.
__________________
W203 (M111) C200K Sedan -- <font size="1"> Kleemann Ring Pulley, H&amp;R Coilovers, C32 Front Brakes, SS Braided Lines, C32 Swaybar, Remus Exhaust, BMC Filter,&nbsp; Bi-Xenons, Comand, CD Changer, Upgraded ICE, C32 Front Bumper, 18" </font>
bajaiman is offline   Reply With Quote
Old 10-15-2002, 12:57 AM   #84
yukpo's Avatar
Drives: 2002 C320
Harris,
Since you upgraded from regular xenon to bi-xenon, is self leveling feature still works fine?
Thanks.
__________________
2011 E300 (Black/Black)
2002 C320 (Silver/Black)
1996 C220 (White/Grey)-Retired
yukpo is offline   Reply With Quote
Old 10-15-2002, 01:25 AM   #85
Ben, the auto-leveling won't work because the cars w/o bi-xenons or xenon as standard equipment don't have the proper wiring harness. If you are thinking of installing them at Evosport, check the Fed and state laws. I remember reading in the DOT regs that it is illegal for anyone but the factory to instal HID's.
Old 10-15-2002, 02:40 AM   #86
Quote:
Originally posted by yukpo
Harris,
Thanks.
Yup!
Old 10-15-2002, 03:13 AM   #87
rrf
Both Xenon and Bi-Xenon
Both Xenon and B-Xenon use an automatic self-leveling system, I am sure it is the same hardware and harness.
To uncloud the mystery, it is basically a potentiometer attached to the front sway bar, and one attached to the rear frame that measures the cars "squat" forward and rear. There is no reason that this same OEM stuff couldn't be added, it certainly isn't complicated.
If I was going from Halogen to either Xenon model, I might check the price of the MBZ harness, if it was more than $100, I would either just set them manually (kind of like every other car on the road), or if I wanted to tweak it, I would make a dial that worked from the drivers seat.
You might say that the self-leveling is a nice feature, but when it comes to value, how much would one pay for it?
Lynn are you saying that it is not a good idea for a "business" such as EvoSport to be in the business of installing HID's, but it is fine for Mach430?
rrf is offline   Reply With Quote
Old 10-15-2002, 03:48 AM   #88
Former Vendor of MBWorld
MBenzNL's Avatar
Drives: some slow@$$diesels
I took the liberty of taking apart 3 203 bi xenon headlights last saturday since these had either broken housings or broken reflectors and I am making undamaged lights out of the broken ones.
I took several pictures that can be found on the following pages:
page 1 with 203 Bi Xenon pics
page 2 with 203 Bi Xenon pics
As you can see on the pictures, the reflectors are attached to the housing with 3 balljoint connections; THESE CONNECTIONS MAY GET LOOSE IN TRANSIT due to dropping/throwing of the box.
I mailed with bagwell abou this and he thinks this is his problem as well. I mailed with yukpo and this was also exactly what his problem was and he solved it.
xraverone, please have a look at the pictures and see if your problem is caused by loose balljoints as well...if so: it is easy to repair.
box996 had a piece broken out of 1 reflector that was caused by throwing/dropping the box for sure...I think I found the solution how to prevent that from future shipped lights. He shipped back his broken light and will be getting a replacement light from me.
Most of the loose reflector problems probably are caused by loose balljoints...that is how most lights (all models) from the MB dealership come as well (when ordered as replacement lights).
The lights I had are all rejected headlights due to damaged housings, scratched lenses, damaged connectors, loose balljoints, whatever else there is wrong with the lights.
greetingz,
MBenzNL is offline   Reply With Quote
Old 10-15-2002, 05:45 AM   #89
gab
can you get bi-xenon for the coupe?
gab is offline   Reply With Quote
Old 10-15-2002, 10:24 AM   #90
Re: Both Xenon and Bi-Xenon
I am saying that the the potential penalties to a business which install HID's will be much larger than the penalties to consumer who does so, assuming that what I think I read in the DOT regulations is correct. It would be cheaper for Evosport to consult an attorney before installing HID's in a customers car than the pay the fine afterward, if it is actually illegal for a business to install HID's.
Old 10-15-2002, 10:37 AM   #91
TimmyC230boy's Avatar
Location: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
Drives: C230 Sports Coupe
Send a message via AIM to TimmyC230boy Send a message via Yahoo to TimmyC230boy
what about a body shop, that has to install HID's to repair a customers car, is that illegal?
__________________
2002 Mercedes-Benz C230 Sports Coupe. SILVER, Bose, Auto, Panorama roof,
Cloth, Tinted windows, Clear Corners built 03/2001
http://free.hostdepartment.com/S/Scylas/MB/index.htm
Throttle Depressed, Driver Very Happy
God made all men. Samuel Colt made all men equal. Gaston Glock made some men more equal than others.
<br>Mercedes Benz Owner's Gun Club, Member # 3
TimmyC230boy is offline   Reply With Quote
Old 10-15-2002, 11:42 AM   #92
If the car was originally equipped with HID's, the answer would be it is not illegal. If they are doing an aftermarket installation, the answer is it is illegal.
I have been searching all morning for the reg, and I can't find it.
Old 10-16-2002, 10:21 AM   #93
bagwell's Avatar
Location: Houston,TX-moving to The Woodlands,TX SOON!!!
Drives: Toyota Tacoma & Lexus IS250
in my sedan, I replaced the halogen with the bi-xenon...it is plug and play....just have to have to computer set to XENON present.
they'll still work without the reset...just have to turn the lites on 10 secs before the ignition
__________________
2006 Lexus IS250
2002 Toyota Tacoma
2004 Corvette coupe-SOLD!
2001 MB C320 BIX/Euro COMAND/C32 wheels-SOLD!
bagwell is offline   Reply With Quote
Old 10-16-2002, 05:02 PM   #94
Drives: 2002 Mercedes C240 Desert Silver Java Interior
Send a message via AIM to RJamesC240
Question Bi-Xenon on Desert Silver Sedan?
Hey, just wondered what you think about a desert silver (beige) C240 with the Bi-xenons. I really liked how they look on a silver sedan, but not sure if it will be too sporty/aggressive on mine. I plan on keeping it stock all the way, other than maybe getting the wood steering wheel eventually. So what do you think?
RJamesC240 is offline   Reply With Quote
Old 10-16-2002, 05:22 PM   #95
Admin Alumni
MB-BOB's Avatar
Drives: See Garage
There's no rule that says only the Silver cars can have fun...
__________________
C320 - '06 Headlights Desert Silver/Java Clear Markers White Star Flat Badge
MB-BOB is offline   Reply With Quote
Old 10-16-2002, 06:41 PM   #96
todd's Avatar
Drives: C230K
Flash to Pass Ilumination Speed
Anyone have any real life experience with the bi-xenons?
I am curious at how quickly the high beams illuminate when using the flash to pass feature as compared to hallogens.
I use that alot ;-)
__________________
Orion Blue, C2, 6Spd, Bose w/changer, C7, COMAND & XM Satellite Radio! I have a fast car, and I am NOT afraid to use it! ;-)
todd is offline   Reply With Quote
Old 10-16-2002, 06:58 PM   #97
MBenzNL's Avatar
Re: Flash to Pass Ilumination Speed
Quote:
High beam is just the simple regukar Halogen bulb in the inner circle of the headlight...Bi Xenon means that the headlight has a reflecting plate that gets switched over when changing from low beam to high beam and back...it just redirects the beam pattern of the low beam Xenon bulb a bit.
It does not have 2 Xenon bulbs, but has 1 Halogen high beam bulb and switching reflecting plate at the 1 and only low beam Xenon bulb.
greetingz,
Old 10-16-2002, 07:05 PM   #98
todd's Avatar
Drives: C230K
Thanks allot!
Cleared up my confusion very well.
Regards,
Todd
__________________
Old 10-16-2002, 07:28 PM   #99
Super Moderator
amdeutsch's Avatar
Drives: MPG+ ROLFCOPTER
Re: Re: Flash to Pass Ilumination Speed
greetingz,
Ok, now I'm totally confused. Somebody please explain to me what Mb was taking about with Xenon last year if this is a Bi-Xenon.
amdeutsch is offline   Reply With Quote
Old 10-16-2002, 07:49 PM   #100
gab
Group Buy for Mercedes W203 OEM Bi-Xenon Coupes and Sedan
I am thinking about organising a group buy for the original mercedes Bi-Xenon headlight assembly as I think many people will be interested.
However we should first get a part number and try to see which MB dealers or parts store (Autoclass, bekkers) will be interested in this buy
Tags
203820111205, 350z, afs, autoleveling, autoteile, bi, bix, bixenon, bulb, c203, c230, cclass, class, cupples, diagram, dts, fix, gc2tone32, halogen, head, headlight, headlights, igniter, ignitor, installing, knefel, kompressor, lamp, level, mbworld, mean, means, mercedes, oem, philips, replace, replacement, travis, w203, w211, w463, w5, wiring, work, xenon
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
