Sign in using an external account
| C-Class (W203) 2001-2007, C160, C180, C200, C220, C230, C240, C270, C280, C300, C320, C230K, C350, Coupe
Sponsored by : My Mercedes Parts ![]() |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2002 C230 Coupe
Installing the ASP pulley on an '02 C230 w/Automatic Trans by yourself...
__________________
(Former ride:)2002 C230 Coupe: Brilliant Silver w/Oyster Leather Automatic trans C5 Package: Panorama roof, Leather, Rain Sensing Wipers, Bose C7 Package: Painted door handles, Aluminum Pedals, larger exhaust tip, 17" wheels Mods: ASP Pulley, K&N Filter, COMAND, UHI phone, Auxilliary Input, CD Changer; Argos Bluetooth, C32 Swaybars, Eibach Springs, 2005 tail lights, BFG 245/40-17 KDW2 on stock C7 wheels, NGK Iridium spark plugs BCPR7EIX-11, AMG rear spoiler, Porterfield R4-s brake pads Last edited by rtking; 12-29-2004 at 09:41 PM. |
#2 |
That 85 ft-lbs was for their older design aluminum pulley. Since the new design uses the factory pulley as a basis you should torque it to 200 ft-lbs per MB.
#3 |
Drives: C230 K
Where did you buy the pully from and how much was it ?
I have a W203 04 C230... Please advice. Thanks !! |
#4 |
Thanks Buellwinkle! I'll tighten again tomorrow to 200 lb-ft. You were right... it does transform the feel of the car! Very nice!
bkmotor: the pulley is for a M111 engined car (2000 - 2002 C230 sedans and 2002 C230 Coupes.) ASP sells them for $650 including core charge. You've got a 2004 C230 with the 1.8 liter motor and I don't think a pulley exists yet for that motor. I think someone is working on a pulley system, but I haven't been following who that might be... Bob
__________________
(Former ride:)2002 C230 Coupe: Brilliant Silver w/Oyster Leather Automatic trans C5 Package: Panorama roof, Leather, Rain Sensing Wipers, Bose C7 Package: Painted door handles, Aluminum Pedals, larger exhaust tip, 17" wheels Mods: ASP Pulley, K&N Filter, COMAND, UHI phone, Auxilliary Input, CD Changer; Argos Bluetooth, C32 Swaybars, Eibach Springs, 2005 tail lights, BFG 245/40-17 KDW2 on stock C7 wheels, NGK Iridium spark plugs BCPR7EIX-11, AMG rear spoiler, Porterfield R4-s brake pads |
#5 |
Drives: C230 K
Bob,
Thank you, for your quick respons... Oh.. well... Thanks again Will |
#6 | |
Drives: 2004 Capri Blue C32
Quote:
__________________
jayitx 2004 Capri Blue C32 ///AMG SL55 Intake Kit, K&N Air Filters, ASP Pulleys, 'C32 AMG' Illuminated Door Sills, |
#7 |
Thanks to Buellwinkle for telling me to torque the ASP crankshaft pulley on to 200 lb-ft. I found a quick way to do it without having to lift the car. I simply inserted an Allen Wrench into one of the lightening holes on the pulley closest to the water pump pulley. Then I inserted the 27mm socket onto the crankshaft bolt. I torqued the bolt gently (to not "shock" the Allen Wrench and water pump pulley/bearing) and then applied steady pressure until I achieved 200 lb-ft. Worked like a charm!
Bob
__________________
#8 | |
Quote:
__________________
#9 |
Me I placed a wrench in the torque converter
and with the factory pullye it's 200lbs-ft of torque! Etienne |
#10 | |
Drives: 2002 c230k
Quote:
__________________
'02 6spd C230K in Bril Silver w/C2, Eibach springs and sways. R1 Concepts Drilled/Slotted rotors F&R. |
#11 |
quick question...
How did you "bump" the starter with the igition? Doesn't the car go into "auto-start" mode soon as you tap the #3 position on the key? i had a fuel pump go out on my ML and soon as you tap the start and let go of the key, the car would crank itself over for about 10 seconds. On my C, I also just tap the key and auto start kicks in. So with out the coils hooked up i would imagine the starter would continuously run for the 10 second cycle.
__________________
1990 190e 2.6 1998 ML320 2003 C320 Sport Coupe driver adaptive electronic 5 spd~C5 & C7 packages~alabaster white~ charcoal leather~pano roof~mb star shift **** 20% tint~bose~euro command system~disk changer~video adapter with dvd/tv/mp3~silverstars~airbox baffels removed TEIN SuperStreet damper kit~AMG sways~18" staggered lorinser LM6 replicas~debadged~tinted tail lights and side markers Netherlands chirp with panic sold new project: BMW Z4 3.0i ROADSTER
#12 | |
Quote:
__________________
#13 | |
Drives: Bantha
Quote:
#14 | |
Drives: 2002 c230k
Quote:
__________________
#15 |
Drives: '02 C230K
I've had my dealer do my pulley, they're cool with it as long as I accept the caveats. When they removed the !st gen aluminum pulley they took the starter off to leverage the flywheel.
__________________
'02 C230K |
#16 | |
Super Moderator
Quote:
Since you've got an '04 230, you have a 1.8L (M271) engine. Try surching for "Pulley upgrade" and you'll find info on pulley kits available for the M271. Limited, but there are a few available.
__________________
w203 FTMFW! w204 FTMFL...until I saw the C204...LOL LINK - Current Mods LINK - Full Car Pics LINK: Supercharger and Exhaust Video |
#17 |
For all those who suddenly feel comfortable with DYI on a pulley install, please note there is no mention of the key in the original post. So, either the author knows what he is doing to the point of it being second nature, or he doesn't comprehend the importance of the key.
Do a search and you should be able to find plenty of examples of what goes wrong when you install the new pulley improperly. Tom |
#18 | |
Quote:
__________________
#19 |
sticking the wrench in the torque converter is nothing
I did it on my car 3 times Etienne |
| Tags |
| 02, 2000, 2002, 2004, 2005, asp, c230, coupe, crankshaft, install, mercedes, nut, plleys, pulley, shock |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| FS: NEW (in Box) Kleemann Ring Pulley for SLK230 and C230. | MagmaSilk | Classifieds | 9 | 07-28-2004 09:13 PM |
| ASP pulley installed in C200K by me | 3pointedSTAR | C-Class (W203) | 13 | 01-29-2003 01:27 AM |
| Crack Shaft Leakage After Installing ASP Pulley | 20FHK02 | C-Class (W203) | 66 | 01-17-2003 06:09 PM |
| report: 2 weeks with ASP pulley | vadim | C-Class (W203) | 56 | 12-16-2002 12:19 AM |
| ASP Pulley | hudkang3 | C-Class (W203) | 5 | 08-15-2002 10:06 PM |
