Anyone know how to get to ashtray lamp?
How do I access the bulb in the ashtray, mine went out and I don't want to bring it for service just for that and would like to do it myself.
a C
Mine went out as well. But MBenzNL aka Steve fixed it when he installed my command.
The whole ashtray was removed and right behind it is where that tiny bulb is located.
Good luck!
Good luck!
Search the forum for instructions on installing command or cd changer, and stop after you get the ashtray out. (Abbreviated version: Remove wood trim around shifter, release clips and remove ashtray).
The following links will help:
http://www.mercedestechstore.com/w20...ideosample.htm
http://phdwebsite.powerpulse.cc/COMA...oval%20WIS.pdf
RJC, don't know what car you have but on the pre-2005 cars like mine with a stickshift, open the ashtray door, remove the ashtray insert, pull hard on the lip of the console piece and will lift up (not too much) and then pull it foward (it's fitted into a groove in the back) and out of the way. Then to remove the ashtray assembly, there's a tab you have to press in the front to release it and it comes out, no force required. When it's out, you will see the wire going to bulb towards the back of the ashtray, pull it out and replace. I'm not sure on the automatic if you have to remove the trim piece around the shifter and put it in a certain gear. As for 2005, I don't know, it's different and I wasn't able to pull up the console easily.
See https://mbworld.org/forums/clk-class-w209/91824-how-install-cd-changer-w209-step-step.html
Section (B) Remove centre console cover panel and radio
Stop when you get to step 8.
Originally Posted by bryanm
See https://mbworld.org/forums/showthread.php?t=91824
Perfect instructions, where do I get the replacement bulb.
They will put it in for you for free. The bulb is also under warranty and is also free.
2011 C63, 2004 S500, 2013 E350, 2013 Ody Elite
Can't believe this...I just bought my car in for Service B and also indicate my ashtray light is out on my C32. My parents pickup the car for me today and the light was not fix. I checked the invoice from dealer and guess what it said..."23383 Checked with Other models the sam, No light in front ashtray. Cigarette lighter has light and work ok". What an idiot! It's @ WI Simonson!! What a SHAM!!! I know there is a light because I have a W203 C320 @ with ashtray light.
Good time to swap over to the SMOKER DELETE...and add in a cool looking 12v covered plug....Steve can hook this part up...the cover swaps over.
It is plug and play...
As to the OP...nice image...here is a shot over Buffalo, NY...
Good luck all...I can try to grab my OEM ashtray and look into the bulb if I get a free moment...
Jake
Jake
2012 C300 4Matic
...is that what you meant by your last post?
