C63 Diffuser w/OEM C350 Tip (Quad) Install & *Pics
Old 10-12-2008, 07:02 PM
VaderSS's Avatar
'06 E55, W204 C350, '04 Carrera C4S, '02 ML55 (Wife's)
Smile C63 Diffuser w/OEM C350 Tip (Quad) Install & *Pics
I’ve found a pretty easy solution if you are having issues finding reasonably priced exhaust tips for the conversion.
After searching & searching & more searching Online, EBay, at Local Exhaust Shops & numerous Private Messages to people that have already done this (using SLK55, E55 tips, etc…) thanks micropower99… My dealer could not get just the tips, only the AMG’s mufflers with the tips $$$.
I have found a Factory Oval Tip with very close width & height (within 1/16”) to the real AMG C63 Tips! I just left the dealer and measured the C63 tips 4-13/16” against the……….… WAIT A SECOND………. C350 sport 4-3/4”
That’s only 1/16” difference! 2.5mm difference to the people outside the U.S.A. The height is the same!
Long story short I ordered them! The cost is only $84 bucks each! I just have to reuse the other two on the car. That’s not too bad for me I just picked up the C350 on Sept. 15th, so my tips still look new.
While these tips may not say AMG on them, they are readily available, OEM, The right Shape & Size. That’s cool with me. My quest to find tips was getting tiring. And… Yes the C350 & C300 are the same part #’s
Also measured the C63 opening and it’s approximately 11-3/4” if anyone was curious.
With the AMG Brackets putting the diffuser on was BOLT IN! No modifications!
Here’s the Parts I used;
AMG Rear Diffuser A204 885 45 25
AMG L & R Brackets A204 885 23 14 and A204 885 24 14
Here are the tip part #’s 204 490 63 27 & 204 490 64 27
*Attach with Rivet
*Attach with Rivet
*** Put back the stock bolt!
*Cut the inside of the two Outer tips
* The inside two tips cut flat
Just after... we made some minor adjustments after driving around the block to let the exhaust & suspension settle
It’s hard to see but the tips are actually evenly spaced I will have to get better pictures to show sometime.
The main differences between using the AMG tips versus the C300/350 tips are that I could follow/match the curved contour on the bumper/diffuser with the edge of the tips, instead of staggering them like the other installs.
Yes, I am aware the factory staggers them but these tips did not look right staggered because the edge is slightly curved to match the bumper. AMG tips are a little bit more squared off on the edge and look better staggered.
Enjoy, give feedback or hate away......
StraightWisdom (09-11-2021)
Old 10-12-2008, 07:08 PM
maverickvii's Avatar
2008 C300 Sport 6M
Those look great Vader, easily as good as the AMG tips. And in my opinion, for something as purely asthetic as exhaust tips, it's not worth paying the way-too-high-prices of AMG.
Old 10-12-2008, 07:17 PM
micropower99's Avatar
2008 Mercedes C300 4Matic
As usual another perfect DIY. Thanks Vader
Old 10-12-2008, 07:18 PM
JasonEB's Avatar
C300 4-matic 2008
Looks very great!!
Did you notice any change of sound after you changed to quad tips?
Old 10-12-2008, 07:32 PM
VaderSS's Avatar
Thanks Guys!
Maverickvii - Thanks! Yup, I agree staggered would have only looked cool if the AMG tips were used.
JasonEB - I did nothing other than add the tips so, no noticeable change in exhaust note… but I am still driving around in ‘C’ mode until I have a 1,000 miles on it. Trying to be good and follow the owners manual.
micropower99 – I still have not gotten around to installing those door sills… But I will!
Old 10-12-2008, 07:36 PM
syrAMG's Avatar
W212 2011 E-350 4Matic
That is by far the most cleanest diffuser add on application done so far!!
very nice!
Old 10-12-2008, 09:56 PM
KuiDaCroat22's Avatar
2008 C-300/ 19' maya MRS black wheels H@R Springs//powerchipped//Brabus Trunk spoiler//HID Fogs//
NICE!
looks great! already PM'd you about the brackets! 2 thumbs up!!
Old 10-12-2008, 10:14 PM
aowhaus's Avatar
2008 C300 Sport 4matic
Excellent job and thanks for sharing your initiative!
Did you get a local muffler shop to fabricate the connection for the new tips, and how much did it cost?
I'm planning on doing this in the spring, possibly with a CF diffuser.
Old 10-12-2008, 10:52 PM
PolePosition's Avatar
C350
Excellent DIY and the result is AWESOME!!!
Maybe that will be my next mod.
Old 10-12-2008, 11:03 PM
Stryder04's Avatar
Benz
if you dont mind, how much was everything including labor?
Old 10-12-2008, 11:17 PM
VaderSS's Avatar
syrAMG, KuiDaCroat22, aowhaus, PolePosition & Stryder04 ..... Thanks!
The Diffuser is a 'No-Fuss Bolt-In' process with no alignment issues.
Here was the price breakdown;
Tips were $84 each x2= $168 .........(204 490 63 27 & 204 490 64 27)
Brackets $24....each x2= $48 .........(A204 885 23 14 & A204 885 24 14)
Diffuser ......................$264 .........(A204 885 45 25)
Rivets......................... Free! ........(had some lying around)
Exhaust custom welding $275
........Grand total: $755
Using all factory parts..... Priceless!
Old 10-13-2008, 12:19 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Nobody can beat that
very well done
Old 10-13-2008, 07:32 AM
MBworld Guru
FrankW's Avatar
white and whiter
thanks for the part number and price
Old 10-13-2008, 08:50 AM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Looks great and an excellent write up.
Old 10-13-2008, 10:30 AM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
very well done
any LOSS of back pressure or performance do you feel or do you think you suffered from the above install?
looks super clean BTW
Old 10-13-2008, 12:39 PM
350driver's Avatar
2010 E63
Looks killer! My next mod for sure!
Old 10-13-2008, 01:13 PM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
def the way to go Vader go job i like it.
Old 10-13-2008, 01:44 PM
myinternetsucks's Avatar
Merc C300 sport, arctic white, P1, MM/Navi, iPod kit, 20% Tint, C63 Grill, X-Pipe, HID DDM Kit
GREAT WRITE UP! did it change the sound of the exhaust note??? can you put it on youtube so i can hear it???
Old 10-13-2008, 02:17 PM
benggolf's Avatar
2010 Prius & Miata MX5 PRHT, 2010 Toyota Venza AWD, 05 C55 AMG, Yamaha 1100 Custom, Honda 250 Reflex
Excellent job and great write-up!
Very innovative of you to utilize the stock tips and the customer welder did an excellent job of lining the tips.
Old 10-13-2008, 02:20 PM
VaderSS's Avatar
tanktube67, FrankW, Ron Jr, 350driver, Spec_Davis
... Thanks! I think it looks factory because it does not have the AMG tips.... I went to the dealer this morning and was told by a tech, 'Hey what option code is that? The AMG 950 sport option?'. I confessed but it made me feel pretty good.
rb23lb & myinternetsucks
... like I was telling JasonEB, I did nothing other than add the tips so, no noticeable change in exhaust note… but I am still driving around in ‘C’ mode until I have a 1,000 miles on it. Trying to be good and follow the owners manual. I'll keep ya posted when I break the 1k barrier and get to floor it!
Old 10-13-2008, 02:30 PM
rb23lb's Avatar
so since you just bought the stock tips... they were not connected to an exaust pipe... therefore, you only changed tips...ok gotcha,...
so people that use AMG tips which come connected to the pipe probably lose performance then, when you do not lose or gain anything I assume?
Old 10-13-2008, 02:55 PM
VaderSS's Avatar
benggolf .....Thanks
rb23lb..... The added tip is functional but I have not driven my car hard yet. I’m still in transmission mode ‘C’ which starts out in second gear and shifts early.
I would suspect no loss/gain in performance.
Now in the sound department, that is yet to be seen. I assume the exhaust note will be a little louder (mega-phone theory) by having two more functional exhaust exits.
I’ll keep you posted when I reach 1000 miles…. I have 922 miles now so maybe in two days?
Old 10-13-2008, 03:40 PM
all good!!!!!!!! still get a vid of it on youtube id like to still hear it!
Old 10-13-2008, 04:55 PM
JohnnyBenz2008's Avatar
08 c300 And 2007 Porsche C4S (997)-Sold
Looks Great
Old 10-15-2008, 12:14 AM
Flame3g's Avatar
CLK500 SPORT
Vader that look clean when i did my mod i should have ask it they had any brackets....your tip set up look very good
Quick Reply: C63 Diffuser w/OEM C350 Tip (Quad) Install & *Pics
