Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class: How to Install Illuminated Door Sills
Step by step instructions for do-it-yourself repairs
W204 Illuminated Sills - DIY
2011 E350 4 Matic
I have installed the doorsills but ran into one problem and am not sure how to connect the cable to the fusebox under the hood (far right corner)
Unlike Mark who posted the DIY (Thanks Mark and Vic Viper) my car does NOT have the fuse box inside the car (left side driver side), and I will have to get the power via the fuse box inside the engine compartment. The instruction are vague but it says "Remove front SAM control unit with fuse and Only on vehicles without interior fuse relay module (N10/1) Do not disconnect electrical connectors."
Any idea why the connection is different then when the fusebox is inside the car?
2011 E350 4 Matic
Just an update and CRY for help
The install of the wiring and doorsills itself went very well but I am puzzled how to get them hooked up to the fusebox. my car does not have the interior fusebox so I had to feed the cable through to the fusebox in the engine compartment and that is where I am stuck.
The cable coming from the doorsill harness has a fuse holder that is supposed to be inserted into the fusebox but I cant figure out how that can be done.
The instructions state the following:
"10.1 Remove front SAM control unit with fuse and Only on vehicles without interior fuse relay module (N10/1) box (F34). Do not disconnect electrical
connectors.Model 204.0 /2 AR54.21-P-1260CW"
Anybody that can help?
#32
2011 E350 4 Matic
Yeah worse come to worse thats what i will do. It's just the fact that all the work is practically done with the exception for the power connection and then having to pay the dealer probably an hour of labour for something that is likely going to take them 10 minutes?
Anyway, i guess thats still cheaper then having them do the entire job..
#33
2011 E350 4 Matic
Just an update. completed the install by using "add a circuit adapter" this gadget allows you to us an existing fuse location and split it to add a circuit with its own fuse.
#37
2011 E350 4 Matic
NP. the install is very easy. the directions in the pdf are very good, found that the hardest part was to connect the wire to the fusebox.
If your car does not have the fusebox on the drivers side then make sure you get that "add a circuit adapter" [URL="http://www.picocanada.com/catalogue/fusesholders.asp"]
#39
2011 E350 4 Matic
Best to search online, the part number is: A204 680 3635 Illuminated door sill panels (set of 2, front). The problem is that the car is still a "new" model, doorsills for older models go for $300 to $400, Dealers here in Canada were charging close to $900 for mine. Doing it yourself save you money.
They certainly add a wow factor when passengers get in Good luck
#40
2011 E350 4 Matic
#42
2014 Ghibli S Q4 & 2008 C350
#43
2011 E350 4 Matic
I bought the OEM ones, I would have purchased the cheaper ones had there been a way to get them "door" controlled vs interior light.
Just look at the bright side that you will save couple hundred bucks by doing it yourself (and some gratification)
Now that it is getting darker earlier it shows very nice......
#45
W204 C180K Avantgarde AT BE
would it not be easier to connect to the courtesy light that is located on the door? it would be a matter of getting the cables and soldering to existing contacts on the door light so when door light goes on/off, so does sill? or am I being too simplistic in approach?
#46
A simpler way is to just tap a connection off the wire, i.e. strip back some of the insulation, wrap the conductor of the connecting wire and then tape it all up to prevent grounding. The most difficult part is finding the correct wire.
