Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W204)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 4.60 average. Display Modes
Old 02-09-2012, 04:08 PM   #126
akmerc's Avatar
Drives: 2012 C300 4Matic
Quote:
Originally Posted by merich42 View Post
Looking to replace my side markers but didtn see any DIY. It is terrible difficult?
2009 C300
Seems like a common mod, but no info for how to do it or where to get replacment lenses....
To remove this ad, register today or login if you already are registered!
__________________
2012 C300 Sport, 4Matic, P1, & Navigation
akmerc is offline   Reply With Quote
Old 02-09-2012, 04:12 PM   #127
Drives: White 2009 C300 Sport
kHuNkHuNa kHuNkHuNa
I've seen side markers on eBay. There 40-60$ and i haven't checked how much the oem ones are. But anyways. I thought about changing mine to clear one with a chrome bulb.
I would like to find a DIY guide as well so its easy to swap them once I get some
kHuNkHuNa is offline   Reply With Quote
Old 02-10-2012, 04:57 PM   #128
Drives: 2008 C300 4Matic Sportretired teacher/professor
Do you have anything definitive on how to change the combination (cabin) filter? What I have found so far is 2 different versions, and before I dismantle my 2008 C300 Sport 4matic, I would like to try to understand what I am doing. Any and all help will be appreciated.
wszypszak is offline   Reply With Quote
Old 02-19-2012, 11:32 AM   #129
Does anyone know how to replace the passenger side marker lamp? My illuminates, but "pop" out slightly at the top. The owner's manual says it is a complex operation best left to a MB dealer. Any and all help is most welcome!!!
Old 02-28-2012, 10:44 PM   #130
Drives: C300, 330i, MDX
Quote:
Have you seen this one? https://www.mann-hummel.com/mf_prodk...u/HBYyDKP4.pdf
__________________
C300S 6MT is offline   Reply With Quote
Old 02-29-2012, 08:00 AM   #131
Yes, thank you,. I am going to the dealer (I still have OEM warantee left) and have them fix it because it is a safety issue if it falls out while driving. All for the lack of a missing 1/2 or metric equivalent screw, a day is lost. Oh well, you want to play in the Mercedes league, bring money- lots.
Old 02-29-2012, 08:02 AM   #132
OOPS- I thought you were referring to my running light situation- yes, I have printed out the cabin filter direction and thank you for your kindness and courtesy.
Old 03-12-2012, 06:40 PM   #133
kevin.vernal's Avatar
Drives: 2009 C63 ///AMG
https://www.facebook.com/kevin.vernal kevin_vernal
Send a message via Yahoo to kevin.vernal
L shaped on my C300
L shaped led on my c300... hope u guys like it...
DIY and How to Guides for w204 All Together-429927_10151398406395521_737355520_22891241_1352790322_n.jpg
kevin.vernal is offline   Reply With Quote
Old 03-15-2012, 08:27 PM   #134
Drives: '10 C63
Is there a diy on how how to take apart the 2010 mirrors? I'm looking to install a set of carbon fiber mirror covers that are a full replacement of the old piece.
r0me0x is offline   Reply With Quote
Old 03-15-2012, 08:52 PM   #135
Quote:
this may work for you... Just installed my "new style" side mirror PIC´S AND WRITEUP INSIDE!!!
__________________
Old 03-16-2012, 02:57 AM   #136
Drives: '10 C63
Doesn't seem to have info on how to take off the OEM painted cover.
Also does anyone have DIY instructions on how to remove the cigarette adaptor from the glove box? I was able to drop the glovebox but couldn't figure out how to remove the cigarette adaptor? Specifically the spring loaded cap?
Old 03-25-2012, 11:20 PM   #137
track_warrior's Avatar
Drives: Like The Stig
Any diy for the side marker install, i just got my smoked ones from ebay but have no clue how to install them.
__________________
l 1997 E-420 Sport l 2011 E92 ///M3 l 2009 Porsche Boxster-S l 2013 Scion FR-S l 2007 Ram 1500 4X4 l
track_warrior is offline   Reply With Quote
Old 03-25-2012, 11:24 PM   #138
kHuNkHuNa kHuNkHuNa
Quote:
a few people have asked the same thing, no one has made a diy guide for it because they all claim its easy.... but for people that haven't done it before, its much better to see how its done before u start taking stuff apart.
if you wanna hold up a week ish, ill take pics and write up one when i do mine.
Old 03-26-2012, 07:25 AM   #139
I had a similar problem in that the marker exterior lens was coming out- I had it fixed because the lone screw that holds it firmlt sandwiched - the lens and the bulb mount- over the bumper cover. I believe you have to remove either the wheelwellpanelor the splash panel to get at it fromunderneath. The owners manual recommends that it is a difficult repair and you should take it back tothe dealer. My repair took less than 15 minutes becausw the shop that helped me has a lift and works on Mercs allthe time.And,by the way, he said it was so simple "nocharge". My point? If you can jack upthe wheel, remove the liner/s you probably will spend more time jacking and unscrewing then changing. The bulbholder assembly has 2 hooks,a clip,and a screw, so you need to be able to reach both inside and outside the bumper cover to get it mounted. Hope this helps.
Old 03-27-2012, 03:58 PM   #140
Drives: C250
Any DIY on painting headlights?
Shadowwolfe is offline   Reply With Quote
Old 03-27-2012, 09:33 PM   #141
mhad2480's Avatar
Drives: 2011 C300 Sport, 2007 Nissan Titan Crew Cab
I posted this on another thread somewhere but...
you have to go through the wheel well. You don't need a lift or to jack up the car, just turn the wheels in the opposite direction of the fender you are working on. There are 3 or 4 plastic "pins" that you pull the center piece out of then you can pull out the body of the pin. Pull the liner away from the quarter panel into the wheel well enough to get your hand/hands in there. The light is held in place by a clip on top you need to release. Then pull the top out away from the fender and the bottom kind of pivots out also. There is a plastic housing on the back side. I seem to remember seeing pics of this somewhere, pictures usually help me more than a narrative, but this really is a pretty simple process. I've done it a few times. Hope this helps.
mhad2480 is offline   Reply With Quote
Old 03-27-2012, 09:46 PM   #142
kHuNkHuNa kHuNkHuNa
Quote:
you have to go through the wheel well. You don't need a lift or to jack up the car, just turn the wheels in the opposite direction of the fender you are working on. There are 3 or 4 plastic "pins" that you pull the center piece out of then you can pull out the body of the pin. Pull the liner away from the quarter panel into the wheel well enough to get your hand/hands in there. The light is held in place by a clip on top you need to release. Then pull the top out away from the fender and the bottom kind of pivots out also. There is a plastic housing on the back side. I seem to remember seeing pics of this somewhere, pictures usually help me more than a narrative, but his really is a pretty simple process. I've done it a few times. Hope this helps.
thanks, it won't be hard for me but theres some that don't want to be taking chances, so when i get mine i'll take pics while i do it, it just another thread and another link on the diy thread, no big deal,
i would love to see a DIY on painting the headlights that would be awesome, i didn't want to attempt that on my own, so I'm just gonna buy the black spyder headlights
Old 04-02-2012, 08:25 PM   #143
kHuNkHuNa kHuNkHuNa
Heres my attempt at making a DIY guide for side markers, hopefully this helps,
I wouldn't mind suggestions either of what i could have done better
DIY, side markers
Old 05-02-2012, 03:18 PM   #144
DIY, side markers
Just completed mine last week. Easy to follow
Niiiico is offline   Reply With Quote
Old 05-14-2012, 11:15 AM   #145
Drives: W204
Any DIY on how to replace/clean the TB on the C300?
Didn't see anything on how to clean or even get to the throttle body on the C300.
1fstrdr is offline   Reply With Quote
Old 05-25-2012, 11:10 AM   #146
Drives: 2009 Mercedes C350
Angry Does Anyone have a DIY for smartkey reset
I have had a recent problem with the smartkey for my 2009 C350. My smartkey went dead. I replaced the batteries and is still will not work. I am hoping there is a trick to resetting the w204 Smartkey....help is desperately appreciated.
jhand1102 is offline   Reply With Quote
Old 06-04-2012, 08:22 AM   #147
RickP330's Avatar
Drives: 2008 Mercedes C300 sport, 1998 SL 600 sport
How to R&R stock horns
Hey guys, any info on how to R&R the Horns on our car? Mine stopped working and mechanics want $350 to replace the high and low. Mine keeps popping the fuse and they tell me the High horn has failed to ground. I don't even know where the horns are. Any help would be most appreicated.
RickP
RickP330 is offline   Reply With Quote
Old 08-07-2012, 02:45 PM   #148
jhov85's Avatar
Drives: '09 Mercedes C300
jhov85
can some one point me to a DIY for removing the chrome strip that runs along the bottom of the car?
jhov85 is offline   Reply With Quote
Old 09-18-2012, 07:16 PM   #149
Drives: C180 2008
Mbenz c180 2008 service message reset
Hi,
New to this site
Anyone knows how to reset service light indicator on c180 auto 2008 model steering wheel has +- buttons on one side and two other buttons on other to navigate through screen
Zane2009 is offline   Reply With Quote
Old 09-19-2012, 12:58 AM   #150
Drives: 2008 GL 450
Wonderful, took the guess work out of it.
crasshh is offline   Reply With Quote
Tags
2008, 300, benz, change, diy, left, license, lights, lower, mercedes, oil, panel, plate, remove, replace, running, w204
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
