Sign in using an external account
| C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: c300
HELP!!! C300 Command Screen flickers 0ff
#2 |
Drives: 2012 C300 4Matic
I just had a crazy idea. Why don't you take it to the dealer?
#3 |
Drives: c300
The warrenty is expired and it can cost up to $7000 to replace the command system
#4 |
Drives: His mama. Traded y0 mama in because she was squeaking.
Or it could cost as little as a "There was a recall on the xyz part, we fixed it."
__________________
Mercedes Benz Owner's Gun Club, Member #85. |
#5 |
Yes, take it to the dealer, just tell them not to perform any work until they tell you the problem...
#6 |
Ever see the movie Michael Clayton? I'd bring that in right away!
__________________
_________________________ Stevens Institute of Technology MSIS Class of 2010 2008 Mercedes-Benz C300 Luxury (click here for photos!) Black on Black | 4matic | Premium II | Multimedia | iPod | Wood/Leather Steering Wheel Previous cars: 2006 Mercedes-Benz C280 (Pewter Metallic) 1999 Pontiac Grand AM GT Coupe (Bright Red) |
#7 | |
Former Vendor of MBWorld
Drives: ML350, Lotus Elise
Quote:
Im not sure exactly what you are askingfor here but If you are looking for other things to check, pull the actual monitor assembly and see if any of the connections are loose directly at teh back of the monitor... Otherwise you might want to start checking ebay for replacement monitors. |
#8 |
Drives: 2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
#9 | |
Drives: '08 C350, '05 Mazda 3 HB, '07 330i
Quote:
![]() ![]() ![]() ![]() ![]() Just had a mental picture of that! ... then he'll see a HORSE ! ![]()
#10 |
Drives: C300 SPORT 4MATIC
Hi, I have the exact same problem with my screen
![]() can u pls tell me how did u fix it ? Thanx
#11 |
Drives: c300
I still have not got it fixed, I suspect its a loose connection, on hot days it works, I will try to take the monitor out and check al lconnections but not sure how to do it, if you have any info that helps let me know
#12 |
Drives: c220
How did u fix the prob having same issue
#13 |
Super Moderator
Drives: late 2009 CLK 350 Coupe Elegance, '65 Jaguar S Type wires
Sounds like the LED screen backlight or ambient light sensor is poked. Could also be a loose connection or dry solder joint. This should be a fairly simple if tedious fix.
__________________
![]() Llandudno, Cape Town, South Africa |
| Tags |
| 2008, benz, c300, comand, command, ignition, key, mercedes, problem, problems, raising, recalls, shuts, volume, w204 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
