Sign in using an external account
| C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: '09 C350 MM
Laser Jammer
__________________
#2 |
Drives: '09 C350 MM
no one?
__________________
#3 |
Drives: \
I almost bought the M27, but I ended up splurging on the Laser Interceptor instead, it just works better. I just had it installed last week and I've been meaning to post pics.. maybe tomorrow. The M27 uses infrared LEDs to blind the guns, and produces jam codes, and eventually they will punch through.. the laser interceptor uses the same laser diodes on the Lidar guns, and can jam all the way to the gun on almost every model, and there's only one gun it will produce a jam code on. There's a discount code for them if you check the radarbusters forum.
#4 |
Drives: C350 W204
about this, what if we were caught? what's the consequences?
#5 |
Drives: \
They are legal where I am, so you should check your state laws.. but it's probably just a fix-it ticket.
#6 | |
Drives: '09 C350 MM
Quote:
__________________
#7 |
Drives: M5, C63, 335Ci
I also have the Laser Interceptor unit. It did the best in the Guys of Lidar testing and has served me well. I'll take a pic or two of the jamming/receiving head installation spot behind my grill, but everything else is behind trim panels, etc. I ran the wires from the heads through the fusebox to allow easy access through the firewall. The control unit is above the drivers side underdash trim panel and the power switch is in the same trim panel. There is a group buy available on another forum that gets you a pretty good discount. PM me for details, but it saves your arund 20% off normal prices.
#8 |
I have been debating the laser interceptor. Which one would you guys recommend, dual, quad, hi-power or not?
It can get pretty expensive, and I would love to see installation pictures, I am not crazy about the fact that the sensors have to be visible. It is pretty cool on the other hand that you can use them as parking sensors for the front and rear (not sure how that works if someone wants to review that). But doesn't it warn when it is actively jamming? If so, whats the need for the valentine one, earlier detection? |
#9 | |
Drives: 2009 C350W on EDP
Better to Bank on Passive Detection and Warning...
Quote:
Notwithstanding the marketing, IMO the effectiveness of active jammers is very dubious. The power/SNR physics simply do not work out in real-world encounters. I think the best defense is sensitive, "smart" passive receivers that looks in all directions simultaneously... like the Valentine. |
#10 | |
Quote:
#11 | |
Quote:
See the attached pics. As far as the warning goes, yes the LI does warn when it detects and then jams the laser. I actually have my V1 built into the center rear headrest and the display in my rear view mirror so the V1 can't pick up laser due to lack of sight to the signal. I used to have it on the windshield and actually programmed it to turn off laser after installing the LI to avoid the alse alarms from laser guided cruise control systems like on the Infiniti cars and trucks. The LI is much more precise in it's detection and doesn't false on those. Last edited by qship5; 08-26-2010 at 11:00 AM. |
#12 | |
Drives: '09 C350 MM
Quote:
__________________
#13 |
#14 |
Thanks for all the info! I think I'm just going to stick with the Valentine for now, and see how it goes. Maybe if I come into a bit of cash I will purchase the laser radar.... Thanks again!
#15 | |
Drives: \
Quote:
As far as the Valentine1 goes, if it detects laser, the jammers will activate. All it does is add a third, very sensitive, receptor to your Laser Interceptor. Useful, and since the LI doesn't have anything to do with radar, you kind of need to have one. |
#16 | |
Quote:
#17 |
Drives: \
It's not a question of how thick it is but how opaque it is... you're blocking a beam of light.. and I think the issue would be from 1000 feet away, not 10. Remember, they try to tag you with the gun before you can see them.
I hope it works for you, I really do. |
#18 |
I understand your point and both the receive and transmit diodes are positioned so that the open part of the mesh is directly in front of them.
I am curious about your earlier post about the V1 activating the LI jamming sequence. How are you doing that? My V1 is not connected to my LI. Is your wired in somehow? |
#19 |
Drives: \
You need this special accessory cable to connect your V1 to LI.
#20 | |
Quote:
#21 |
Drives: '09 C350 MM
Ordered M27, where do you think I should put them? I've seen then installed in the grill, or in the lower outside bottom grill....
__________________
| Tags |
| buy, c230, class, connected, group, interceptor, jammer, laser, li, m5, plain, review, reviews, sight, v1 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
