Sign in using an external account
| C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2009 C350
S mode better MPG
#2 |
Drives: W204, W220, S15 Silvia
a lot of times its the way you drive, heavy foot in low rpm gives the engine more trouble than lighter foot in high rpm given the same acceleration to achieve, thats why it makes sense
__________________
#3 |
Drives: 2009 Arctic White/Black C350 with NAV pkg, ipod integration, 40% HO tint, and 18" 5-spoke AMG wheels
#4 |
Drives: 2008 C350 Sport
I have also found that I get better mileage in S mode and it's a lot more fun to drive in S mode. I have reserved C mode for winter weather conditions only.
#5 | |
Drives: 221.122 & 212.025 & 204.089
Quote:
You are correctly setting the conditions same, the comparison would not make sense otherwise but if you have a look at the engine efficiency figures, it would give better mileage for the same given power at a lower rpm but higher load. I've attached an example of an older MB engine, it should give an idea even if the data is not fresh. For a given acceleration at a given speed you need certain engine power. The figure shows that this power is reached at a higher efficiency at a lower rpm in all typical cases rather than at a higher rpm where the engine load unavoidably gets reduced. This of course only works at the power levels that are reachable with a lower gear (which is always the case if we talk about transmission mode C against S). |
#6 |
Drives: C300 4matic
My wife just drove 60 miles and got 21 mpg (all highway)
Funny thing is I did the same drive in my family's S550 and got 26 mpg .....WTF
__________________
'10 C300 4matic Sport Steel Grey/ Grey & Black MBTex ![]() Email me at SOLN6184@AOL.COM |
#7 |
Drives: 09' E350 AMG Sport, 09' C300, 03' Honda S2K
I drive it in C because the smoother shifting. That is about it. Not sure if it should be that much of a difference in MPG though. Ummm
#8 | |
Drives: 2008 C300 Sport, RWD, US
Quote:
I typically get 30-31 mpg on my Sunday 200 mile drive. Its almost all highway driving with the cruise control set to 70mph. Your wife my just not have driven far enough to get a true miles per gallon. Were you using the "since reset" or "since start" figures? |
#9 | |
Drives: C300 4matic
Quote:
Edit: btw filled up the night before and it was on 3/4 tank last night so the computer is actually showing higher mpg. (17 gallon tank which means about 4 gallons was used which should have taken me 80 miles not 60)
__________________
'10 C300 4matic Sport Steel Grey/ Grey & Black MBTex ![]() Email me at SOLN6184@AOL.COM Last edited by clkcadet; 09-03-2010 at 12:40 PM. |
#10 |
Drives: 2010 C300 Sport, 2007 335i Sedan
Geez... I only get 21-22 mpg at best in C mode. Maybe I drive too aggressively. S mode is NEVER better than C, especially on the highway because I believe S mode never sees 7th gear.
#11 |
lkevinl
Its 1st gear that doesn't happen in "C" mode. 7th gear kicks in at around 53 mph. If you want to test it, drive 55 mph and move the transmission shifter to the left briefly. Note that your rpm increased and your dash display shows 6th gear. |
#12 |
Drives: Skoda FABIA
I to have tried both modes when i switch to C mode i get mileage of 27-28 mpg and when i switch to S mode i get mileage around 25 mpg ..
#13 |
Drives: 2011 C300
The only thing C mode does is start the car off in 2nd gear. From there, all is the same. Also, if you go WOT from a stop even in C mode the car will use 1st gear. It should make absolutely no difference with MPGs, you're seeing things.
#14 |
Using "s" mode also causing the transmission to have slightly higher shift points.
#15 |
Drives: W204
I took a nice 80 mile drive out to The Hamptons today sticking my cruise control on 55 mph and on the C mode ...... well was i pleasantly surprised when i saw that i was able to hit an all time high mark of 33 MPG
!! Driving back home still using the C mode but a little bit more aggressive drivign at about 65 / 70 mph i was still at about 25 MPG which i still dont think is that bad ![]() Soo with that being said if S mode provides better mileage....... what would've my MPG been in the morning if i was in S and doing 55 mph WOW ??
__________________
2008 Steel Grey C300 4Matic CF Roof Spoiler CF Trunk Spoiler CF Side Mirror Covers Clear Sidemarkers 8000K HID Kit AMG Replica Wheels X Pipe ![]() |
| Tags |
| 07, 09, 2010, 335i, 4matic, c300, drive, gallon, mersedess, miles, mode, mpg, shift, smode, sport, start |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
