Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W204)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 09-03-2010, 07:47 PM   #1
Drives: '08 C300 Sport, '07 ML350, '06 E350, '08 VW Jetta 2.0t Wolfsburg Edition
before/after alignment specs
I had both of my front struts replaced because of a clunking noise from the front end (sorry, I have two other threads going about that issue ), these are the specs after the strut replacement (before) and then what the dealer set my alignment to (after).
Now, my car seems to pull to the right pretty bad (when I let go of the wheel when driving, the steering seems to just turn to the right), and the steering wheel seems off center to the right also. Don't the specs seem to read okay though? And what is "steer ahead"? I'm guessing this is why my steering is cocked to the right a bit.
Thanks for any info. I'm heading back to the dealer next week.
Click the image to open in full size.
To remove this ad, register today or login if you already are registered!
__________________
08 C300 Sport-Palladium Silver/Gray MB tex *iPod integration * 7Gtronic
-35% 3M Color Stable tint
-AMG trunklid lip spoiler
-OEM LED taillights
10 ML350-Steel Gray/Black *Premium II*Heated Seats*Exterior Appearance*Trailer Hitch
11 E350-Palladium Silver/Ash*Premium I*Wheel Package*Roof & Trunk Spoiler*Black Birdseye Maple
akbro93704 is offline   Reply With Quote
Old 09-04-2010, 12:01 AM   #2
Stone2486's Avatar
Drives: 2008 C300 4matic Sport
Have you checked you tire pressures? If the front right tire pressure is low it can cause a pull. Also what are the tire conditions?
__________________
08 C300 4Matic Sport - C63 Rims w/ Michelin Pilot Sport 2's Front 245/40 ZR18, Rear 265/35 ZR 18 - 20% Tint All Around - Xenon Fog Retrofit - Magniflow True X-Pipe
Stone2486 is offline   Reply With Quote
Old 09-04-2010, 06:18 AM   #3
Drives: 2008 C350
I may be taking a risk with my first post here not knowing what I'm talking about
But...
I remember being told once that there should be a slight pull to the right. The idea being.. you fall asleep, you won't end up left-of-center.
Full disclosure tho that this could be complete BS!!
encoder is offline   Reply With Quote
Old 09-04-2010, 06:33 AM   #4
huir's Avatar
Drives: 2010 W204
How did this happen to you car? I mean the original front clunking noise issue.
__________________
The next, R8.
huir is offline   Reply With Quote
Old 09-04-2010, 06:49 AM   #5
Drives: 2008 C300 Sport, RWD, US
Did your front tires show any unusual signs of wear????
JimPap is offline   Reply With Quote
Old 09-04-2010, 08:20 AM   #6
Super Moderator
amdeutsch's Avatar
Drives: MPG+ ROLFCOPTER
Lets also not forget the road crown.
__________________
amdeutsch is offline   Reply With Quote
Old 09-04-2010, 09:52 AM   #7
Sportstick's Avatar
Drives: 2009 C300 Sport 6 speed; 2008 E350 Sport 4MATIC: 2009 Jeep Liberty Sport (boat/deep snow/dogs!)
Yes, but they warn about that!
__________________
08 E350 Sport 4MATIC - Indium
09 C300 Sport 6 Speed - Palladium
Eibach Anti-Sway Bars
Michelin Pilot Sport A/S Plus & Blizzak WS60
Akebono EUR 1340/1341 Brake Pads
AMG Style:
> Euroteck Diffuser
> JBSpeed Trunk Spoiler
> BMWChop Roof Spoiler
> Bodycolor Grille
> Performance Products Steering Wheel
> 17" PowerWheels Pro #810
AZN LEDs/Bodycolor Tail Lamp Trim
Philips X-treme H7
White Star Badge
HiTech Wheel Flaps
Sportstick is offline   Reply With Quote
Old 09-04-2010, 10:34 AM   #8
Drives: C
What's the road crown? Never heard of this
Samieee is offline   Reply With Quote
Old 09-04-2010, 10:49 AM   #9
Stone2486's Avatar
The road crown is to allow for proper draining so water doesnt puddle up on the road
__________________
Old 09-04-2010, 11:00 AM   #10
Sportstick's Avatar
Quote:
That real sign was a low quality visual pun on my part, but it doesn't work at all if you're unfamiliar. I took driver's ed in NYC, just where you are...and they taught about the crown in the road back then regarding water draining, drifting, etc....not anymore ???
__________________
AMG Style:
> Euroteck Diffuser
> Bodycolor Grille
Philips X-treme H7
White Star Badge
HiTech Wheel Flaps
Old 09-04-2010, 12:15 PM   #11
Tire pressures are even, thats the first thing I always check. Front right outer edge of tire is wearing quicker. I've had alignment issues from day one with this car. And it's definitely a harder pull than a normal road-crown pull.
__________________
-OEM LED taillights
Old 09-04-2010, 01:01 PM   #12
Did it have the same pull before they swapped parts and realigned?
If it did, I think I'd be looking at a broken belt on one of the tires.
If the pull is more severe than before, then I'd be looking at the wrong parts being put on or the alignment being off. I see that you have a E350 and a C300. Wonder if they somehow mucked that up and either put the wrong parts on or used the wrong alignment specs.
....or more simply, did the alignment wrong.
Old 09-04-2010, 07:35 PM   #13
RLE
RLE's Avatar
Drives: '08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
BS
Quote:
But...
It is, in fact. This is just another one of those excuses for a bad alignment job. Drive an MB long enough and you will hear them all.
RLE is offline   Reply With Quote
Tags
2007, 2008, ahead, alignment, blizzak, c280, center, e350, end, front, grid, mb, rear, spec, specs, steer, steering
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
