Sign in using an external account
| C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
X Pipe Installed - Detailed Post Analysis and Common Questions Answered
__________________
2011 C300 4MATIC Last edited by Distinct; 01-31-2011 at 04:39 PM. |
#2 |
this is a great write up, im about to do this mod so this was very helpful, thanks a lot!!
#3 |
How many times this needs to be covered in forums...
D - Significant change and obtrusive and annoying (There's your D answer)
__________________
![]() A wise man once told me: "My anaconda don't want none unless you got buns, hun!"
#4 |
Sorry for offending you. Not trying to cause any problems. Just trying to be helpful.
__________________
2011 C300 4MATIC |
#5 | |
Drives: 2009 Arctic White/Black C350 with NAV pkg, ipod integration, 40% HO tint, and 18" 5-spoke AMG wheels
Quote:
I found this to be helpful and there's no need to be a D about someone trying to help others out. Appreciate the post.
__________________
![]() 2009 Arctic White/Black C350 (mine) 2011 Blizzard Pearl/Tan Toyota Highlander Limited (wife) 2006 Chili Red/Black Mini Cooper S (sold) 2000 BMW Silver/Black 323Ci (sold) |
#6 |
this was by far the best write up about the x-pipe mod, once again thanks. let the haters hate lol
#7 |
Drives: c300
i actually hear a lot of noise from inside the cabin at 50mph and it gets even loud as i accelerate. It's a really annoying noise that was not there the first two months. Anyone know what it could be, it loud enough to pop your ears.
#8 |
Drives: W204 C280
Distinct, I really appreciate your post as I'm also considering getting an X-pipe. Very helpful! keep it up!
#9 |
Hope this write up helps all the new members.
__________________
. Powerchip ECU tune K&N Filters Black Out window & trunk molding/ by JS Design Factory Black Out side marker lamps Black Out Grill Tint tail lights "cherry red" C63 OEM wheels on Pzero tires 35% window tint H&R Spring Euroteck CF front lip DDM 6000K HID kit Custom quad exhaust by Royal Mufflers http://www.mbworld.org/forums/c-clas...quad-tips.html |
#10 |
Drives: C300
I had the mod done today, and completely agree with the assessment ... I'm also in Toronto fwiw
#11 |
Drives: '09 C350 4M, '11 Sienna SE, '84 VW Jetta GLi
I would like to add that this is the case with a c300.........
Here's my assessment for my C350 with the Magnaflow X-Pipe....... 1. Idle with windows up = B 2. Smooth acceleration (never exceed 3000 rpm) from stop with windows up = B to C 3. Aggressive acceleration (3000 rpm to 5000 rpm) from stop with windows up = C 4. Smooth acceleration (never exceed 3000 rpm) from stop with windows down = C 5. Aggressive acceleration (3000 rpm to 5000 rpm) from stop with windows down = C 6. Cruising on the highway = B to C 7. Driving in manual shift mode and keeping higher rpm (3000+ rpm) = C 8. Engine Start (warm or cold) = B+ on Warm and C on Cold. |
#12 | |
Drives: 2010 C350
Quote:
I have a C350 and I agree with you. |
#13 |
just had the xpipe installed, and i must say its nice
........on to the next mod......
#14 |
X-Pipe Installed
+1 on that, had mine done too at my local meinke shop cost me a haggling of $169 including all taxes, extra extenders and labor (cost $25 per weld here). As its probably not the best welding job i've seen, but sounds awesone as i just recently took my car into the benz dealer for a tire replacement (got a flat), the porter said it sounded like a C63, made my day...
#15 |
Drives: 2008 C300 Sport
Hey man thanks for the informative post, really got me thinking of adding the x-pipe to my car.
#16 |
Drives: C300 Sport 6 Speed Manual
Sounds like you have a cracked weld or a loose clamp joint. I would take it back and let the exhaut shop take a look as it shouldn't be that noticeable.
#17 | |
Quote:
![]() I did have them take off the resonator's as this is the only way get the x-pipe on. If you look at my pic, you will notice that i did not have them take off the clamps the meinke mechanic showed me what he was going to do before doing the work and gave his opinion and said this was the better setup for future mods to the exhaust or replacement before the resonator's. |
#18 |
I know some people have issues with the road noise and have gone as far as putting sound dampening material in the trunk where the spare tire is. Have you done that or is it all stock? I'd love to have that more aggressive sound, stock is way to quiet for me, but I just don't want an annoying drone at cruising speeds.
Also, if anyone can answer this; any change on the MPG after doing such a mod? I understand if I take off from stops to hear the sound it's going to go down, but if I were to say drive the way I do now (not so aggressive accelerations and no lead foot on the highway) would there be a difference? |
#19 | |
Quote:
Everything else so far is stock in terms of the exhaust portion or ECU, which my next future mod will be the EuroCharged tune. I did put in drop in air filters by Green, only seemed to make a barely noticeable change if any to my mpg or hp wise. With the X-pipe mod, if your gonna keep on driving the same way then no it shouldn't change at all. But i will give you a warning, in this honeymoon stage; i cannot stop from revving or taking off just to hear that exhaust, haha ![]() I hope this answered your questions, i would love to also add the Meistershaft exhaust later on but its not a cheap mod. I also added the taillight overlays and side marker covers from a local shop and cost me a total of $120 out the door. I will add the link so you can check them out. Tail Light Overlays - I need your opinions! Peace. |
#20 |
Drives: LOADED! 2008 C350 Sport (Wht/Blk Pano)
hey Brian check out how mine was installed, they put the pipe extenders on the opposite end... do you think it makes a difference which side you put the extenders on?
![]() ![]() Magnaflow Stainless Steel 2.25" Tru X Pipe INSTALLED -08' C350 - (SEE UNDER CAR PICS) As compared to your installation:
#21 | |
Quote:
I dont think that it makes a difference in sound quality wise, have you checked out my sound clips and maybe you can compare it to see if it does. Also as far as performance zippo difference in either set up. |
| Tags |
| 545, automatic, bmw, c300, class, hp, instal, mercedes, pipe, poppong, rpm, tuning, xpipe |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
