AZNOptics.com Storefront - W204
#426
2010 C350/ E46 M3/MK5 DUB
#427
I switched out my internal lights to LEDs but dont have any bulb for the rear dome. do you have any? Also, do you sell fog lights? Both of my fog lights are out.
#428
SPONSOR/MBworld Guru
Rear dome uses a set of 194 wedge and a single 41mm festoon. We have that. For fogs, we carry Morimoto HID kits and also have Plasma H7 bulbs, although the plasmas will require additional load resistors.
#429
Formally announcing that all our V3 units have not been adapted with Gel Packs. This is a high temp resistant gel substrate that we've applied to the resistor and critical solder joint to both help encapsulate the heat and insulate against heat soak, making these units more durable against heat and electrical surge related incidents.
#432
2008 c300 4matic Sport
thanks for the info. I ordered 3x W5W 5k LEDs from your site. Heard they match the diamond vision's H7 fairly well!
#434
AZN. I ordered 3 pairs of w5w LEDs a bit ago and finally got around to installing them. Got the eyebrows done but had a rookie mistake losing one in the engine bay with no luck recovering so I'm short one doing my side markers now. I want to order a pair for my trunk lid too. Do you offer an oops discount or anything? I need a set and a 1/2 or maybe a discount on 2 sets?
#436
Sure, we can work out a deal. Email us at aznoptics@gmail.com or PM with your PayPal email address and we'll take care of you.
#438
Here's the link to our H7 Morimoto Elite HID kit in 5000K (pure white)
http://www.aznoptics.com/index.php?m...products_id=65
We also have it in 6000K (white with a slight bluish hue)
http://www.aznoptics.com/index.php?m...products_id=67
Just put in your complete mailing address and it'll calculate shipping cost for you.
#443
I need to check if I can get this installed here in Shanghai first!
But you can quote me to zip 200040, Shanghai China
#444
2010 C200 CGI
Technically no, even if you get away with it for your daily drive, you'll have to pull it for china's MOT inspection. We have the same issue here in SZ, luckily our car does mostly highway so we avoid hassle from the local "police".
#445
Introducing new H7 and H11 Plasma LEDs that are ideal for w204 fogs (H7 for Sport, H11 for Luxury). These kits will be paired with new big block Morimoto Load Resistors. These retail for $60/kit
http://www.aznoptics.com/index.php?m...products_id=91
http://www.aznoptics.com/index.php?m...products_id=92
#447
C-350 2010 RWD
Hello Mike,
What is the advantage / disadvantage of the plasma VS HID? I want the white look of HID 5000k for both my headlights and fog lights. I am looking for something reliable.
I am presently on halogens and I tried the rip offs Sylvania Silverstar but not happy with the color. (still yellowish)
Please note: I have converted my 2010 C350 to the 2014 C63 look but my headlights have some projector lens (aftermarket headlights) Also not to confuse anyone I have the C63 LED daylight strip but also my original fog lights which I have installed behind the front grill in the center.
Thanks for the info!
#448
For any light you rely on for forward projecting visibility, definitely want HIDs. LEDs are more for indication type lighting unless the housing was specifically designed to project LED light spread. So for your headlights, fore sure go HIDs. Fogs, you can either go HIDs or LEDs as you're not relying on those to illuminate. HIDs will look brighter and do a better job filling out the reflector, but the LEDs aren't slacking too much either. We wanted to offer a more cost effective fog option for our customers which is why we came out with these plasma LED units.
#449
C-350 2010 RWD
Thank you.
#450
Typically because of how low the fogs are to the ground and not directed up, you're not going to blind oncoming traffic with HID fogs.
The plasma LEDs come with the required Morimoto external load resistors to tap in and eliminate codes.
