How to remove side mirror lenses? - MBWorld.org Forums
C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI
Sponsored by : MB Parts Factory
Click Here
LinkBack Thread Tools Search this Thread Rate Thread
Old 07-02-2011, 07:43 PM   #1
Drives: c63, 11 e350 (DD)
Are they just "pry" out, or do you need to dis-assemble the entire mirror?
I'm getting them smoked, and need to take it to the body shop. Thanks for the help.
stangxs is offline   Reply With Quote
Old 07-02-2011, 07:59 PM   #2
xXHotelCrazyXx's Avatar
Drives: 2008 W204 Sport
Push on the bottom part of the mirror glass with your fingers to expose a large gap at the top of the mirror. Then with as many fingers as you can get in the gap, evenly disperse the pressure with your fingers while pulling straight out. The mirror is held in by a circular clip almost 2" diameter. Just be firm and even while pulling outward with the glass
xXHotelCrazyXx is offline   Reply With Quote
Old 07-03-2011, 01:58 PM   #3
Drives: 2014 SL550
+1
blue00r6 is offline   Reply With Quote
Old 07-03-2011, 02:08 PM   #4
Drives: W204 C280
careful not to break it, or else thats 7 years back luck!
albert101 is offline   Reply With Quote
Old 07-03-2011, 03:09 PM   #5
Sorry I didn't clarify! I actually wanted to take the turn signal lense on the side mirrors off, not the actual mirror off. Thanks for the info though!
Old 07-03-2011, 03:53 PM   #6
Mixedfruits's Avatar
Drives: E63 Black on Black
Quote:
Yeah in order to get the turn signals off you need to dissasemble the whole mirror I did it before. Step one take out mirror second pull out the mirror lense you can pry out with a flat head from there you will see many screws just un screw them. At that point everything is out of the mirror but the housing and the turn signal, some more screws 2 to be exact and the turn signal is out!
Mixedfruits is offline   Reply With Quote
Old 07-05-2011, 03:19 PM   #7
dcjwlee's Avatar
Drives: 2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
Quote:
I'll have to try this to see what's causing all the condensation in my side mirror turn signal. I can live with the eventual corrosion and yellowing, but there is NO way in hell I can ever go without the auto-tinting driver's side mirror! (And rearview!)
good post!
dcjwlee is offline   Reply With Quote
Old 07-05-2011, 03:27 PM   #8
SPONSOR/MBworld Guru
AZN Optics's Avatar
Drives: MB W204, BMW E66, Porsche 958, VW MK6 TDI, Maserati Ghibli SQ4
Hmmm, I should try this and see what kind of lights are in there...
AZN Optics is online now   Reply With Quote
Old 07-05-2011, 03:35 PM   #9
Quote:
please I was tempted to change out the leds in them to white but the leds are different than regular one its a flat led and the progs are really small and I think soldered on
Old 07-05-2011, 04:27 PM   #10
AZN Optics's Avatar
If it's soldered in, then it's gonna have to be a custom job unfortunately. I'll take a look though and see what I can do.
Related Topics
Thread Thread Starter Forum Replies Last Post
Side view mirror gaskets installed CTSV_OR_E55 W211 AMG 39 12-15-2016 05:23 PM
W220 Windsheild Wipers sabri S-Class (W220) 11 09-23-2016 11:16 PM
WTS: W212 Side mirrors with autodim/heat/blind spot chickenprotein W212 AMG 0 09-06-2015 04:42 PM
New owner checking in sam i am C63 AMG (W204) 11 09-06-2015 05:42 AM
Anybody else have problems with MY16 C300? jakc C Class (W205) 9 09-04-2015 11:50 PM
Tags
2011, c220, c230, e350, glass, lens, mercedes, mirror, mirrors, pull, rear, remove, removing, side, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
