How to remove side mirror lenses?
Old 07-02-2011, 06:43 PM
stangxs's Avatar
c63, 11 e350 (DD)
Are they just "pry" out, or do you need to dis-assemble the entire mirror?
I'm getting them smoked, and need to take it to the body shop. Thanks for the help.
Old 07-02-2011, 06:59 PM
xXHotelCrazyXx's Avatar
2008 W204 Sport
Push on the bottom part of the mirror glass with your fingers to expose a large gap at the top of the mirror. Then with as many fingers as you can get in the gap, evenly disperse the pressure with your fingers while pulling straight out. The mirror is held in by a circular clip almost 2" diameter. Just be firm and even while pulling outward with the glass
Old 07-03-2011, 12:58 PM
blue00r6's Avatar
2017 C43
+1
Old 07-03-2011, 01:08 PM
albert101's Avatar
W204 C280
careful not to break it, or else thats 7 years back luck!
Old 07-03-2011, 02:09 PM
stangxs's Avatar
c63, 11 e350 (DD)
Sorry I didn't clarify! I actually wanted to take the turn signal lense on the side mirrors off, not the actual mirror off. Thanks for the info though!
Old 07-03-2011, 02:53 PM
Mixedfruits's Avatar
E63 Black on Black
Yeah in order to get the turn signals off you need to dissasemble the whole mirror I did it before. Step one take out mirror second pull out the mirror lense you can pry out with a flat head from there you will see many screws just un screw them. At that point everything is out of the mirror but the housing and the turn signal, some more screws 2 to be exact and the turn signal is out!
Old 07-05-2011, 02:19 PM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
I'll have to try this to see what's causing all the condensation in my side mirror turn signal. I can live with the eventual corrosion and yellowing, but there is NO way in hell I can ever go without the auto-tinting driver's side mirror! (And rearview!)
good post!
Old 07-05-2011, 02:27 PM
SPONSOR/MBworld Guru
AZN Optics's Avatar
Hmmm, I should try this and see what kind of lights are in there...
Old 07-05-2011, 02:35 PM
E63 Black on Black
please I was tempted to change out the leds in them to white but the leds are different than regular one its a flat led and the progs are really small and I think soldered on
Old 07-05-2011, 03:27 PM
AZN Optics's Avatar
If it's soldered in, then it's gonna have to be a custom job unfortunately. I'll take a look though and see what I can do.
Quick Reply: How to remove side mirror lenses?
