stance sc5ive and hr springs
2009 Evo X 420 AWHP, 2012 C250 Sedan
and for reference i measured height before and after from center of wheel fender to ground
before:
front 25 7/8 inches
rear 26 1/8 inches
center of front bumper to ground 8 inches
after:
front 25 3/8 inches
rear 24 7/8 inches
total lower front .5 inch rear 1.25 inches
no more rake!
before:
front 25 7/8 inches
rear 26 1/8 inches
after:
front 25 3/8 inches
rear 24 7/8 inches
no more rake!
275 may be cutting it. If no 5mm pads maybe but during compression might be close. Imma put one of the wheels on a speed bump later to compress the other side to see how much it clears
'09 C350 4M, '11 Sienna SE, '84 VW Jetta GLi
I'm going to run 225/40 and 255/35 on my sc-5ive's
- 1/2" taller side wall for a little more comfort
- will fill the wheel gap a little more
- little more stretch for clearence/rubbing issues when fully loaded with weight.
- when speedo reads 60mph actual speed will be 62mph
225/40r19 AND 255/35r19 are exactly the same size....... the 1/2" taller (all around) is compared to stock 225/40r18 and 255/35r18.
My c350 is a 4matic, so I have to run the same size tire all round.
