Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W204)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-12-2012, 11:18 PM   #1
MBfinatic's Avatar
Drives: e36 318i, 2004 sti
https://www.facebook.com/tim.hall.980 HK SHIFTY
Great mod for the C350!
Just did a mod to my C350 and loved it! Just thought I would pass it on to everyone! The top end pulls so much harder!
I upgraded the intake manifold and throttle body from the 272.969 motor (slk 350 09-11).
The parts!
Click the image to open in full size.
The intake manifold,
Throttle body, You will also need an elbow to mount it all together.
The install,
Remove the airbox and ecu.
unplug these connectors.
undo fuel pressure valve
The valley!
There are more in between steps I just didnt take pictures. Overall great mod and recommend it to anyone trying to make more power out of their m272!
To remove this ad, register today or login if you already are registered!
MBfinatic is offline   Reply With Quote
Old 04-13-2012, 08:43 AM   #2
Thaa kiid Jlee's Avatar
Drives: 2011 c300 4matic
Jon Lee Call Mee Jlee
Send a message via AIM to Thaa kiid Jlee
is this mod only for the 350 or it works for the 300 as well
__________________
2011 c300 4matic
CHECK IT OUT!
v
My Build Thread: http://mbworld.org/forums/c-class-w2...011-build.html
Thaa kiid Jlee is offline   Reply With Quote
Old 04-13-2012, 08:49 AM   #3
MBfinatic's Avatar
This would work for the C300 as well. The gains will not be as high but it will still work.
Old 04-13-2012, 08:52 AM   #4
how much did this all cost you
__________________
2011 c300 4matic
CHECK IT OUT!
v
Old 04-13-2012, 08:55 AM   #5
MBfinatic's Avatar
The intake manifold was about $240 (brand new with gaskets). The elbow was about $40 brand new. Than the expensive part is to find a throttle body. I would recommend buying one used. I paid $450 for my throttle body. They can be bought from around $400-500.
Old 04-13-2012, 09:04 AM   #6
C300Sport's Avatar
Drives: C300 Sport 6 Speed Manual
What did you do with the ECU to account for the different setup?
C300Sport is offline   Reply With Quote
Old 04-13-2012, 09:14 AM   #7
MBfinatic's Avatar
So far I havent had the ecu changed at all. There are no codes for it. I have been driving it like this for some time. The ecu slowly adapts to it somewhat. My tuner already has the files ready (has done this before to other cars). It runs fine now but of course with a tune it will run better.
Old 04-13-2012, 09:40 AM   #8
hitokiri89's Avatar
Drives: 2010 c350
Any idea what your gains are ?
hitokiri89 is offline   Reply With Quote
Old 04-13-2012, 09:47 AM   #9
MBfinatic's Avatar
Quote:
Not yet. I will be taking it to the dyno again after the re flash and I fix my master cylinder
Stock I put down 232whp and with the cat removal I did 235whp. Im hoping to at least hit 260whp if not more .
Old 04-13-2012, 11:13 AM   #10
Drives: '11 C350 '08C350 (gone) '06 F250 Lariat
I have read the slk 350 makes more stock HP than the new style C350s. I see in your sig that u have an 06, they are exactly the same? I thought I read somewhere that there were some basic changes, Im wondering is it a straight R&R to a w204 too?
jimmythegreek is offline   Reply With Quote
Old 04-13-2012, 11:22 AM   #11
MBfinatic's Avatar
Quote:
Yes my engine is the same M272.960 A straight R&R?
Quoted from Cale himself.. (Another 06 C350 6spd owner)
"Using the 09-11 SLK350 w/ M014 upgraded engine performance pkg (with the "red stripe" on the engine cover) as a muse, I've been in the process of upgrading several key components of my 3.5L engine designation 272.960 to the upgraded fare in the engine designation 272.969 found in that particular SLK350.
Ratings:
"c350" aka 272.960:
approx 270 hp @ 6500rpm
slk350 aka 272.960
approx 300hp @ 7200rpm"
Here is a picture from Cale that shows the stock manifold and the manifold used on the SLK 350
Old 04-20-2012, 08:05 PM   #12
MBfinatic's Avatar
Has anyone decided to do this mod?
Old 04-20-2012, 09:20 PM   #13
hitokiri89's Avatar
Drives: 2010 c350
I'll probably do the throttle body , hard to say ill commit to the intake when the stock intake is so good . Also I don't know if it drops right in on the w204 chassis .
Old 04-20-2012, 09:22 PM   #14
MBfinatic's Avatar
It will work just fine. Also you cant just do the throttle body, You have to use all these parts together. Im hoping to be hitting around 260whp with the tune. Why wouldnt it fit on the w204?? The is to the engine?
Old 04-20-2012, 11:14 PM   #15
hitokiri89's Avatar
Drives: 2010 c350
Idk , I guess because no one has done it on the w204 yet . When you hitting the dyno ? I'm not against being the first guy to do it but I have a lot mods coming up so it wouldnt be for a few months . Why can't I just do the throttle body ?
Old 04-20-2012, 11:16 PM   #16
MBfinatic's Avatar
Well you can be the first! Its the same motor! If you need help your free to pm me. I should be hitting the dyno shortly after I move (have a lot of stuff to do). Well because the inlet to the intake manifold is a different size. What other mods are you doing? This is a great mod for top end performance!
Old 04-20-2012, 11:25 PM   #17
hitokiri89's Avatar
Drives: 2010 c350
New wheels coming in so I need tires , throwing stock mufflers back in for back pressure , Akebono brake pads , new grill , gonnd do suvneer's 63 style bumper , need to buy tips for stock mufflers , smoking head lights and fogs , hid conversion for fogs , full exterior and interior led swap . Powdercoat the new wheels , and sway bars . A lot of stuff lol . Also I got my new tune coming up too .
Old 04-21-2012, 12:12 AM   #18
MBfinatic's Avatar
Sounds like you have a lot to do. I cant wait to get back on track with the mods.
Old 04-22-2012, 12:34 PM   #19
Drives: 2010 SLK350
A w204 c350 owner over at MBJunkies already has done the intake manifold conversion.
Regardless of the chassis, an m272 is an m272. Specifically in regards to this swap, it's a viable option for ANY chassis.
The 09-11 SLK300 also has this setup, but all of the SLKs also have 3.23 final gear ratios, allowing for loss in low-end torque due to tumble flap deletion. Unless the 3.0L owner plans on following up with the 272.969 cams & valvetrain, I would stay away from this mod as a c300 owner. The c350 still has poor gearing (I corrected this the best that I could with a gear swap from the stock 2.82 to 3.07), but it has enough extra power, that after a tune - the loss in low-end is tolerable considering the incredible gain in the upper RPM.
It has been documented (Karo) that with the appropriate tune for the manifold/TB from OE Tuning (& OE only, Jeremy has dyno-tuned this mod personally), that 30 extra hp can be had, peaking somewhere near redline.
RedStripe is offline   Reply With Quote
Old 04-22-2012, 02:42 PM   #20
MBfinatic's Avatar
Im excited to get my tune!
Old 04-23-2012, 12:08 PM   #21
I was looking at throttle bodies the other day and it seems that the same one is used in alot of the MB cars, the part # cross references many platforms and engines. Is the one listed in this thread a specific one to a performance package on the SLK? I can get these parts pretty cheap Im just wondering if its worth the trouble
Old 04-23-2012, 12:18 PM   #22
MBfinatic's Avatar
If you have the 3.5 than I would do it. Like he said its not worth it on the smaller motors. I would do it again on a C350 no doubt.
Old 04-24-2012, 06:46 PM   #23
rb23lb's Avatar
Drives: LOADED! 2008 C350 Sport (Wht/Blk Pano)
damn jimmy the greek let me know if you do this mod.... I trust your judgement after reading all your posts so if you have success I think I am going to buy these parts as well
will be the first certified 30hp mod for the w204 c350 yet!
rb23lb is offline   Reply With Quote
Old 04-24-2012, 07:51 PM   #24
MBfinatic's Avatar
I will be posting a dynograph soon.
Old 04-26-2012, 08:43 PM   #25
Drives: 2009 c350 arctic White pano. MM HK
Keep us updated i think ill do it 2
until the end is offline   Reply With Quote
Tags
2006, 2008, 2010, bodies, body, c350, class, intake, kit, mercedes, mod, moding, mods, throttle, tune
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
