Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W204)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 04-14-2012, 04:16 PM   #1
hitokiri89's Avatar
Drives: 2010 c350
Mufflers rubbing heat shield .. Help !
What can I place on the muffler to stop the rubbing ? Also my tips are rubbing my diffuser . Don't want to remove my heat shield .
To remove this ad, register today or login if you already are registered!
hitokiri89 is offline   Reply With Quote
Old 04-14-2012, 07:13 PM   #2
Thaa kiid Jlee's Avatar
Drives: 2011 c300 4matic
Jon Lee Call Mee Jlee
Send a message via AIM to Thaa kiid Jlee
remove mufflers
__________________
2011 c300 4matic
CHECK IT OUT!
v
My Build Thread: http://mbworld.org/forums/c-class-w2...011-build.html
Thaa kiid Jlee is offline   Reply With Quote
Old 04-23-2012, 08:11 PM   #3
hitokiri89's Avatar
Drives: 2010 c350
Lol exactly what I'm gonna do
Old 04-23-2012, 08:45 PM   #4
Quote:
really i just guessed on a solution !
__________________
2011 c300 4matic
CHECK IT OUT!
v
Old 04-23-2012, 08:47 PM   #5
hitokiri89's Avatar
Drives: 2010 c350
Gonna put the stock ones back in , car is way too loud with the magnaflows bro .
Old 04-23-2012, 09:16 PM   #6
so you would not recommend magnaflow mufflers with the x pipe replace the resonator and a quad tip setup?
__________________
2011 c300 4matic
CHECK IT OUT!
v
Old 04-23-2012, 09:28 PM   #7
chewychiu's Avatar
Drives: 2010 C350
Quote:
I have the magnaflow x-pipe with delete resonator with stock mufflers and quad tips. Sounds loud enough for me. You would notice the difference between that and stock. I'm thinking with their mufflers, it would be much louder?
chewychiu is offline   Reply With Quote
Old 04-23-2012, 09:29 PM   #8
hitokiri89's Avatar
Drives: 2010 c350
It's hard to get then to sit right , just the mufflers and x pipe sounded pretty good but once I removed my cats it sounded terrible .
Old 04-23-2012, 09:34 PM   #9
okay good to know thanks! hopefully ill see you around town
__________________
2011 c300 4matic
CHECK IT OUT!
v
Old 04-23-2012, 09:45 PM   #10
hitokiri89's Avatar
Drives: 2010 c350
Yea , think I'm backing out of the oe tuning day , pretty expensive even with the discount .
Old 04-23-2012, 10:52 PM   #11
chewychiu's Avatar
Drives: 2010 C350
oh man!!
i'm plan on going friday later afternoon
Old 04-24-2012, 11:35 AM   #12
Drives: '11 C350 '08C350 (gone) '06 F250 Lariat
hit up an auto parts store and swap out the rubber hangers for longer ones, thats how I did it. I had to do it on the meisterschafts I have now, they wouldnt sit level no matter what. Only bad thing is you pretty much have to have the car on a lift, unless you can jack and jackstand it and slide under to adjust them.
jimmythegreek is offline   Reply With Quote
Old 04-24-2012, 11:54 AM   #13
SPONSOR/MBworld Guru
AZN Optics's Avatar
Drives: MB C300s, BMW 745Li, VW Golf TDI
you can also bang on the hanger arm a bit to adjust it a bit lower, but longer rubber hanger coupler works as well as jimmy mentioned.
AZN Optics is online now   Reply With Quote
Old 04-24-2012, 12:54 PM   #14
hitokiri89's Avatar
Drives: 2010 c350
I had them lower to begin with and really had no rattles but after I had them adjusted the rattles got way too buisy . Also since I have straight pipes with the headers the car is just too loud with those mufflers on . I put the stock resomater back in but still an issue . I think for my purposes throwing the stock mufflers in will be a win win . Less drone , more back pressure .
Tags
bmw, c350, class, fix, forum, guard, heat, mercedes, muffler, rattle, remove, rubbing, series, shield, slk55, st, underneath
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
