Sign in using an external account
| C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 2010 C350 Sport
Any Engineering Menu Experts On Here?
#2 |
Drives: '11 C350 '08C350 (gone) '06 F250 Lariat
The VIM should be doing this for u, i dont think its in the MM menu. Where did the midcity patch cable plug into? U may have to go into the rear displays and set the input up to the appropriate selection, thats how my co workers ML was done
#3 | |
Quote:
I was in the MM menu last night and saw an option for entertainment but I don't want to screw around with the different options too much. |
#4 |
when I first got this 2011 I was doing my system and was playing around w engineering to adjust some settings and ended up hanging the system up, when it finally cleared I lost disc and sirius settings in the MM screen. Had to go to dealer for a reload of the software! be careful, I thought i had mastered it haha. The ML i helped on didnt have an option to turn on output to rear entertainment, the patch cable just picked up signal and setting the input on the headrest monitors instantly worked. I would say try the sub menu for entertainment and make notes, turn on and if not working turn that back off and on to the next one. Thats how I did stuff when playing/testing things......
#5 | |
Quote:
Thanks |
#6 | |
Drives: 2008 W204
Quote:
but definitely be careful in engineering mode everyone |
#7 |
Drives: 08 C300
to reset DVD reginal code setting, press hang up + * + # where Remaining Changes is showing 0.
It should bump it back to 5 or 10 so that you can change it again. |
#8 |
Drives: 2008 W204
when it first happened i was gonna post a question on here but i figured no one knew how to fix it, this worked perfectly, thanks!
| Tags |
| activate, benz, c300, engineer, engineering, gain, increase, lct, mb, menu, mercedes, mm, mode, option, vim, w204 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
