Go Back   MBWorld.org Forums > Mercedes-Benz Sedans > C-Class (W204)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Insurance Search Today's Posts Mark Forums Read CarsGarageVendors
Welcome to MBWorld.org Forums
C-Class (W204) 2008-Present: C180K, C200K, C230, C280, C300, C350, C200CDI, C220CDI, C320CDI
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 06-16-2012, 01:44 PM   #1
05 MB Komp's Avatar
Drives: 2010 C350 Sport
Chirping sound
Hey guys,
My 2008 C300 sat for a couple weeks while I was on vacation and now it is making a strange sound that is coming from the motor. It kind of sounds like a chirp, it happens when I am driving and while it is idling.
Here is the weird part though, it only does it after about 5 minutes of running and it will go away after 10 minutes or so.
It is driving me nuts and I need to figure out what is doing it.
Any ideas?
To remove this ad, register today or login if you already are registered!
__________________
2005 Black C230 Kompressor - Gone - www.midnightkompressor.com
2008 Mars Red C300 4Matic Sport - Totaled on 7/17/12 (Not at Fault)
2010 Arctic White C350 Sport - Pictures coming soon!
05 MB Komp is offline   Reply With Quote
Old 06-16-2012, 02:13 PM   #2
Drives: 08 GSXR1000, 2007 C230 SPORT, 89 190E
the belt is common for this type of noise after sitting for a while. i have corrected it many times by using some needle nose pliers and very lightly touching some sand paper to the belt while its running. ( Be careful, dont need to go overboard just gently against the belt for 2-3 seconds should do it, if thats what your problem is. Otherwise it could be the idler pulley next to the water pump.
j21importer is offline   Reply With Quote
Old 06-16-2012, 02:19 PM   #3
05 MB Komp's Avatar
Quote:
The inside part of the belt or the outside part?
I will give it a try tonight.
__________________
Old 06-16-2012, 02:26 PM   #4
inside part with the ribs usually does it, good luck.
Old 06-16-2012, 09:14 PM   #5
2012c350's Avatar
Drives: 2012 C350 / 2001 F150 4x4 / 1998 Cobra Convertible
As was mentioned, it definitely sounds like a belt/pulley issue. But before I'd apply any lubricant or 'sand' a belt, I'd just let it go for a few hundred miles and see if it goes away naturally...I'm thinking it most likely will.
__________________
2012c350 is offline   Reply With Quote
Old 06-17-2012, 10:45 AM   #6
Drives: 2008 mercedes-benz c300 4matic sport
Lucky u my belt was half shredded so I had the chirping sound nonstop. Thank god for warrenty
vanbong84 is offline   Reply With Quote
Old 06-17-2012, 12:02 PM   #7
Drives: Mercedes w204 2012
For me, I hear a metallic sound at the back of my car... It's a new w204 2012... I become really nervous with this!
__________________
olive1 is offline   Reply With Quote
Tags
2012, 4matic, c300, c320, car, chirp, chirping, chirps, constantly, key, kompressor, mercedes, noise, strange, w204
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2001-2012 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
Everyone's Personal Details
SEO by vBSEO 3.5.2
