Retrofitting 2011/2012 Speedo in a 2008 C Class
Old 03-07-2015, 11:13 AM
  #51
jay_007's Avatar
C250
So am able to use this speedo A2049004308 (also off a W204). The shape looks different to the speedo I mentioned before.
Old 03-07-2015, 11:32 AM
  #52
Minuszeit's Avatar
204.054
Yes, this speedo will work after adding code 442 for 12-button wheel and digital speedo to Vedoc. As I mentioned before, you just have to change the upper part of the facelift speedometers housing against the old one.
Old 03-07-2015, 07:00 PM
  #53
Doa
Doa's Avatar
W205
what has the facelift version that the pre facelift doesn't have? or is it just the different look?
Old 03-08-2015, 07:56 AM
  #54
Minuszeit's Avatar
204.054
It is just the multicolored look.
By comparison the pre facelift monochrome speedo looks pretty antiquated.
Old 04-26-2015, 12:02 PM
  #55
kman2k's Avatar
W212
Originally Posted by Minuszeit
Yes, you just have to shorten the faceplate.
Remove W204 headunit, install 212 headunit and thats it. It is really a simple thing.
Btw, it is also possible to upgrade to NTG4.5. I developed a converter so that one can maintain the W204 pre facelift display. Just one/two minor shortcomings have to be fixed.
Just went to my car to show you the bt streaming function of 212 NTG4.
Thanks, I will try this mod tommorow ...ntg4 (w204) to ng4(w212).
For the upgrade from ntg4 to ntg4.5 ... I tried before but not works, if @Minuszeit or someone done it sucessful please share how it can be done.
Old 04-26-2015, 12:24 PM
  #56
Minuszeit's Avatar
204.054
In 2-3 weeks the upgrade from NTG4 to 4.5 is done.
The problem is not to make the HU run, the main problem is to make it run with the NTG4 flip screen unit due to the different LVDS signal. My DIY converter NTG4 LVDS to NTG4.5 LVDS signal is still in progress.
Old 04-26-2015, 12:45 PM
  #57
Doa
Doa's Avatar
W205
cool make a seperate topic then
Old 07-19-2015, 08:28 PM
  #58
Kobzarhomes's Avatar
2011 Mercedes E550 Sport
Minuszeit: how difficult was it to install W212 climate control on your W204?
Was there allot of modification that you had to to make it work.
Did you have to purchase a specific control unit to match your W204 car?
Thank you
Old 07-19-2015, 08:36 PM
  #59
Minuszeit: also you mention this in earlier post: "As I mentioned before, you just have to change the upper part of the facelift speedometers housing against the old one."
What do you mean that we have to chance "upper part" "agains the old one".
Do if I have 2010 C300 W204 and I purchase speedometer from 2012 W204. Do I need to use/keep my old cluster housing and swap out the internals of the speedometer?
Thank you for all the info
Old 07-20-2015, 09:53 AM
  #60
AMG893's Avatar
2010 C63 Estate
subscribed.
Want to see the outcome of 4 - 4.5 and the convertor solution!
Make sure to sell them to us!
Old 07-29-2015, 11:06 AM
  #61
Wilsonkpham's Avatar
W212-X204-W204
I love the Color Cluster
Old 08-29-2015, 01:06 AM
  #62
ap10046's Avatar
CLS500 M113
I retrofitted the facelift speedometer in my pre facelift 204 one year ago.
It's also possible to enable the AMG menu in non AMG speedometers.
Pardon my question, but did you need to SCN code it or connect it to STAR?
I already have the 12 button SW and the Monochrome MFD Speedo
What would happen if you took a new cluster and plugged it in directly without SCN/STAR?
My Stealers here are a bunch of tossers who don't want to help in any way at all!
Old 08-29-2015, 01:08 AM
  #63
ap10046's Avatar
CLS500 M113
Thank you
+1 Please?
Also, how did you manage to get the wood panel? Can't find that anywhere..?
Old 09-01-2015, 10:53 PM
  #64
angrybober's Avatar
W204 2008 C300 4matic
I also retrofitted some parts of the W212/C207.
- Comand headunit NTG4
- Air condition panel
- Memory switches of the front door control panel
- Front/rear overhead control panel
- Nappa leather armrest
- Nappa Airbag of the R231
Where did u get Air condition panel? How much did it cost? Did it require any soldering / firmware updates or just plug-n-play?
Old 11-22-2015, 07:17 AM
  #65
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Hows it goin here??
Old 11-25-2015, 01:01 AM
  #66
ap10046's Avatar
CLS500 M113
any more info please..?
Old 06-13-2016, 10:01 AM
  #67
karedox's Avatar
w204
i want to know more info also about the climate control W212, is it plug and play?
and how about the electric seat controller W212, also plug and play?
thanks
Old 05-17-2017, 10:48 PM
  #68
C350King's Avatar
2010 Mercedes C350 Sport, 2006 Mercedes C280, 2001 BMW 530i
Yeah...so no one have any info concerning the AC panel and how to modify the wood panel? Would like to do that mod. Same with memory door switch.
Old 02-16-2018, 08:08 PM
  #69
aznmode's Avatar
2010 c300
Bringing up old thread. Does anyone know if the PCB on pre-facelift cluster the same as the facelift PCB?
Old 02-17-2018, 12:30 AM
  #70
C350King's Avatar
PCB boards are different, to get a newer cluster in a pre-facelift you have to do some soldering and programming. I personally gave up after a few months. Mercedes really makes this all more difficult than is reasonable.
Old 02-17-2018, 02:10 AM
  #71
This swap is very easy if you send the unit to me. I can code it for you and your car. If you have Star Diagnose with Vediamo I can code it to your car remotely.
Here is also My site: www.ckmcardesign.se
Old 02-17-2018, 02:43 AM
  #72
C350King's Avatar
Awesome, don't we have to send both clusters though? And instead of coding remotely, is there a walk thru that could be written up? And how much would it cost for you to do it?
Old 02-17-2018, 02:53 AM
  #73
shoot me an email...chris@mbsca.com
Old 02-20-2018, 04:54 PM
  #74
aznmode's Avatar
2010 c300
Thank you! Good info!
Old 02-20-2018, 04:57 PM
  #75
aznmode's Avatar
2010 c300
Email sent
Quick Reply: Retrofitting 2011/2012 Speedo in a 2008 C Class
