C300 transmission problem?
I have an 09 C300 that I've had since new, but just went out of warranty on Aug 1. Now I believe I'm having an issue with the transmission. Some of the new symptoms include: It revs higher than normal before switching to 2nd gear. When slowing down, it now feels like a manual when downshifting and there's an abrupt/jerk when putting the car from P/R into Drive.
I last had the car serviced at the end of July at the dealer before the warranty ran out and asked them to look at the transmission, but they claimed nothing was wrong with it. Could this just be it needs a software update?
Thanks in advance for your replies.
I forgot to add, that it doesn't do this all the time. Sometimes I'll turn the car on and the entire trip it will be fine. Other times it will have this problem the entire ride. Everytime I turn the car on, I don't know if I'm going to get normal trans or the problems I experience.
Considering you have just come off warranty and you asked them to take a look at the trans while you were still under warranty, you should be in good shape. I would call your SA to discuss the matter.
MB should be more than happy to take care of it...if not, use your powers of persuasion and persistence!
Good luck!
Just saw your second post. Get a video of it is possible. That is how I got my light switch module replaced when the dealer couldn't replicate.
Good luck!
I only have 34,800 miles on the car. It is due for the B5 service. I'll probably be looking at the new CLAs when they come out on the 20th so that's why I was holding on to the car.
Since the warranty expired due to time vs mileage, MB will probably be more apt to cover it (at least labor perhaps) if indeed the transmission is going south. First things first. Need to get a definitive diagnosis...
No it's RWD. I only feel it in the lower gears. Has anyone else had this problem? I've read somewhere about a software update for the transmission. I'm hoping it's not a mechanical problem.
1 Post
Mercedes Benz C300 Sport 4Matic
I have the same issue with the transmission jerks. Yes, I had the transmission flush or fluid replaced at 39K miles as required by MB. I bought it to the dealer tohave it check out and ended up $1,300 out of my pocket. They replaced the "Conductor Plate" and "Valve Body" took them a week because of the parts come from Germany. Yes, this is on my 4matic.
I bought it back today after two months of hoping the jerks is fixed after out of $1300. The car still jerks, MORE then before, but only at 9-10mph. SO, I was told at today pick-up that they RESET the ECU or Transmission mapping. Let's hope this work?
A software update would be a major help, i had the jerk/surge/pushing forward while slowing down or sometimes braking. After the trans update, it didn't really happen anymore. I took it the dealer and they say there's nothing wrong with the trans, no error codes pop up.
1 Post
So I done all the work and got charged extra for nothing?
Well- report in on the driving. There is no more jerks or rumble at any speed. But i notice the RPM jumps high from 1st to 2nd rear (at 9-10mph), where it used to jerk. It feel much faster then before in C-mode. When I switched to S-mode, it seem not as fast as in C-mode, it does hold the rear a bit longer. So good so far, let see how long this will last.... Have an Excellent weekend everyone !!
Disappointed in Car
My c300 has under 50K miles and was making a whining sound when I drove it and it was jerking as it is shifted.
it seems it needs new transmission front pump assembly. Good thing I purchased the extended warranty.
https://mbworld.org/forums/images/smilies/werd.gif
1 Post
Hi janedelgado.
It's a great car just minor issue. I have 84K on mine C300 4matic.
I had drove it after the 2nd returns to the dealer. They said go and drive it for awhile and see.
Well, I've been driving in "C" mode since I bought my car in 2008, rarely switch over to "S" mode.
Two weeks ago, I decided to switch over to "S" mode and drove it for two weeks; about 2 tanks of gas ~ 500 miles. and I switch it back to "C" and No-more "shifting-jerk" between 3-4miles. The problem is SOLVED !!
Not until this afternoon when I drove it again in "C" mode.
I parked the car outdoor overnight @ 10deg F. Noon temperature is @ 45deg F with 30 second "warm-up", and with a 50 feet Reversed and Drive straight, the car DID "shift-Jerk" a bit. It is better than before, you won't notice it if you don't look for it.
I believed that the in "S" mode the car start with 1st gear and on "C" mode it start on 2nd gear. So with my driving in "C" for the past 5 years. I think the dealership resetted and updated my car EU after my initiated repaird. The EU is trying to grab-hold of the 1st gear as you start but EU told it to let go in "C". That could cause the "shift-jerk" as it release from 1st n grab hold on the 2nd gear. Just my thinking
I'll report back after more "S" mode driving with a tank or two of gas and see.
I am kinda bummed to read all the post regarding transmission issues. I just picked acquired my c300 4matic with 20k miles and the intention to drive is another 100k miles. I just got rid of an Audi A4 with 168k trouble free miles. I am suddenly feeling like I may have just picked a time bomb ticking away after reading all the transmission issues and the ignition switch issues. Additionally premature front strut failure. Warranty or not, I need to depend on the car and hate ever taking it to the dealer.
1 Post
I think you are fine with your. I should have NEVER bring it back to the stealership. I should have just alternate driving between "S" and "C". I felt like an A$$- let them hijacked over $1K from me. I don't know how your driving style is - but I use to drive run it over pot-holes thinking it's a Benz, it should be tough n all. WRONG. My OEM wheel was bended and the dealer charged me $600 for ONE wheel n tire replacement.
I said no and drove the grab out of it and when to PowerWheels and got all 4 new wheels and tires, did the square set all for under $1k. Now, I'm driving it like a virgin - avoid all pot-holes, if I can. .
I have No other issue other then the transfer case leak, shift-jerk, and premature wear on rear tire due to staggered wheels setup. Like I said - my is ~84K 15K more to go till it hit 100. I don't forward see anything wrong with it. by the way - mine is a 2008 4matic got it when it was 114miles. Good luck with yours.
Redfox
Thanks for the re-assurance. After 13 yrs and 168k miles with my Audi since new, the C300 has some big shoes to fill. The Audi A4 B5 platform was bulletproof. I really enjoy the ride and style of the c300 . It's such a great looking car...beats the Audi hands-down.
could something not properly done in service ruin transmission
I had my transmission start to make noises 'just after' I had a standard service done on my car. It was just a few thousand over 50K so my warranty is now finished.
The service advisor mentioned nothing being out of the ordinary with my car at that service and at the time of that service, my car was not making any strange noises when I drove. Shortly after that service, it started making strange noises and I'm being told it has to do with the transmission.
Never have had any concerns with anything on mechanics of car before; AND I have done all services required on my car.
I'm concerned something wasn't done properly in the service; possibly something with fluids and now possibly there is a problem with my transmission after the fact?!?
I live in Orange County, California.
I'm not sure what I should be doing.
m.mbworld.org/forums/showthread.php?t=355695&styleid=20
^^What if this was your problem the whole time? Its possible the dealer diagnosed it as a tranny issue to milk you for money.
I have an 08 4matic with 70,000 miles and the trannys alright knock on wood, but im wondering if it ever goes, will i be able to put a tranny from a 2012-13 c class? Reason being the trannys from the newer cars are updated and probably shift faster, more efficiently and just better overall. Im sure the mounting points are the same, the issue i could see though is software/electronic compatibility.
08 c300 sport
I have a 2008 c300sport automatic trans. I'm looking into doing a much needed tranny flush. Can any of you guys tell me what kind of tranny fluid my car takes?? I can't find anything on this.
2015 c-300 rear wheel drive gear shift jerk
I just brought 2015 c-300 rear wheel drive with 2000 miles. I noticed that when I shift gears (P to D, or D to P, or D to R) it jerks the car. Is any one else had this issue? Is it normal or indication of some issue with transmission?
08 c300 sport
