Debadging trunk
Old 04-15-2014, 11:52 AM
ickdeep's Avatar
'13 M5 | 08 C300 (Sold)
Question Debadging trunk
Hey guys,
I wanted to de-badge the back side of my car for a unique look. I think I'll keep the Mercedes logo but remove the C300 emblem.
Is there any hints or tips that can help while removing them? holes? what items do I need for it?
Thank you
Old 04-15-2014, 11:56 AM
luc1f3r's Avatar
C300
No holes in anything on the sides, c300/4matic/AMG. Star has 3 holes at the very center, very close together.
I did my 2012 about 6 weeks ago and just pulled each letter off. Goo-gone would help if you have trouble, fishing line if you’ve never done it before, plastic / credit card if you’ve done it before and pay attention.
Old 04-15-2014, 11:58 AM
Quicksilv3r's Avatar
2008 BMW M3 Sedan 6MT - Silverstone II/Fox Red Extended
Dental floss or fishing line is perhaps the safest method.
Old 04-15-2014, 12:06 PM
w204_Generic's Avatar
2011 C300 4Matic Sport
I used the hair dryer/dental floss method. Make sure you heat up each emblem real good with the hair dryer before attempting to dislodge it with the dental floss. Fishing line is more reliable and won't break as easily, however you should be careful not to damage the paint.(Most likely you won't)
Old 04-15-2014, 12:23 PM
TheRulesLawyer's Avatar
C350
Hair dryer/ heat gun to warm up the badge. Fishing line or maybe even dental floss to cut it off. Remove the goo.
Old 04-15-2014, 12:35 PM
ickdeep's Avatar
Thanks guys, I'll probably try it tonight if I have time.
Old 04-15-2014, 12:40 PM
Andriy242's Avatar
14' E63S
Its the easiest and one of the best mods to do.
Heat gun and any type of string really. Post pics when you are done.
Old 04-15-2014, 01:08 PM
Akhafeez's Avatar
2004 C240 4matic, 2009 C300 4Matic
I jsut did mine yesterday. Real quick and easy mod. really clean look. just gotta be gentle and goo gone the remaining glue.
Old 04-15-2014, 01:16 PM
Dizm's Avatar
08 C300
I just popped mine off. Then used goo gone.
Old 04-15-2014, 01:51 PM
Cillys's Avatar
2011 C300 Sport 4MATIC
You can also remove the chrome trim at the bottom of the doors. Gives it a cleaner look.
Old 04-15-2014, 04:47 PM
Carlos.33193's Avatar
C250 2012
Apply a little bit of wax over the area after you remove all the glue.
Old 04-15-2014, 10:29 PM
givenshome's Avatar
2010 C300 Sport
I did mine just using dental floss. Took me maybe all of 15 minutes
Old 04-16-2014, 12:11 AM
ickdeep's Avatar
Does the chrome trim on the side have any holes after you remove it? Do you have any pictures of it removed? I really don't like that trim and I want to get rid of it
Old 04-16-2014, 02:56 AM
c350nubie's Avatar
'08 C350 Sport
I believe there is no hole after you remove the chrome door molding. Same with the badge they are held on with adhesive. You can remove using the same method. Share us some pics once you done
The door moldings are the only chrome pieces left unwrapped on my car. Somehow I am fighting against the urge to get rid of it. I like those pieces there but I just dont like that they are chrome. I plan to wrap them all with 3M 1080 M227 matte blue metallic vinyl. Hopefully it comes out nice on steel grey metallic
Old 04-16-2014, 08:09 AM
luc1f3r's Avatar
C300
before / after of door trim removal.
and another after where its easier to see
and a couple of shots of the debadged rear and star replaced.
Old 04-16-2014, 09:05 AM
chrisridebike8's Avatar
'10 C63
Make sure you heat the badge and then use fishing line. I used kite string because it cuts better and doesn't break. Then I use a 3M adhesive remover wheel (available at auto parts stores) to take off all the stickies. It's much safer than goo gone. It looks like this.
http://www.zorotools.com/g/00052324/...FRQaOgodaz8AHw
Old 04-16-2014, 04:26 PM
C350
Is that a camera in your spoiler?
Old 04-16-2014, 04:44 PM
ickdeep's Avatar
End result:
Thank you guys for your help +advice
Old 04-16-2014, 07:38 PM
luc1f3r's Avatar
C300
No, camera is in stock location. That's just a reflection of the emblem.
Quick Reply: Debadging trunk
