Old 06-29-2015, 03:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting Guides
Print Wikipost
new LED Projector Headlight Pair
Old 05-03-2014, 08:08 PM
  #101
Thrilla's Avatar
2014 C63 AMG 507 sedan
Any issues with condensation with these? They look really good, hopefully the quality is good too.
Old 05-03-2014, 08:10 PM
  #102
w204_Generic's Avatar
2011 C300 4Matic Sport
Originally Posted by x942k6
Can someone take a few more pics against a wall?
Is 6000k too blue? I am worried it might be too blue in the rain...
Old 05-04-2014, 01:41 PM
  #103
christophsky's Avatar
2014 E350 4MATIC
6000k is definitely not too blue - for me it is the ideal color temp. I aimed the low beams a little bit higher than they were when I got them.
I also put duct tape around the wire holes in the dust caps to reinforce the seal. 40% chance of rain tomorrow...
Old 05-04-2014, 06:32 PM
  #104
Clkboi's Avatar
CLS550 4Matic
Looking good
Old 05-04-2014, 08:11 PM
  #105
achance's Avatar
2017 E300 Sport
Subscribe
Old 05-04-2014, 11:34 PM
  #106
sev7nflow's Avatar
2013 C250 Sport
could you describe exactly how you adjusted the headlights up? Mine are a bit too low as well and I'm not sure how to adjust them up.
There was a picture of where to adjust the screw at the 'top right' but im not exactly sure which screw they are talking about
Old 05-04-2014, 11:59 PM
  #107
2014 E350 4MATIC
If you look at dirty panda's second pic in post #37, it's the white plastic screw in the back of the headlight. It is adjusted from the top with a 7/32" hex key. The adjustments are very subtle, so you will have to turn it several times. Be gentle as the gears inside the headlight are made of plastic.
Did you resolve the issue with your left headlight?
Old 05-05-2014, 12:18 AM
  #108
dadirtypanda's Avatar
c250
A: Makes the headlight cutoff go up and down.
B: Makes the headlight go left and right and helps keep the hood and headlight flush when you close the hood.
I don't know what C or D do exactly? High Beam Adjustment?
Old 05-05-2014, 10:00 AM
  #109
sev7nflow's Avatar
2013 C250 Sport
B was a huge pain to bolt in and now one of my headlights isnt exactly "flush" with the hood when closed. Is it supposed to be perfectly centered before the bolt is fully tightened from the underside?
did you mean it will adjust the lights inside of the assembly left and right?
Old 05-05-2014, 10:02 AM
  #110
sev7nflow's Avatar
2013 C250 Sport
Yes, looks like I had a bad ballast... in the process of getting it replaced by fishcake. SHould have no problems after I get a new ballast!
Old 05-05-2014, 10:04 AM
  #111
sev7nflow's Avatar
2013 C250 Sport
is the duct tape recommended to keep moisture out?
Old 05-06-2014, 05:45 PM
  #112
x942k6's Avatar
2010 White C300 Sport
Can someone comment on the quality of these headlights? Now we just need a brave volunteer to go through a automatic car wash lol
Old 05-06-2014, 10:41 PM
  #113
Clkboi's Avatar
CLS550 4Matic
Quality is great IMO. Like i have said before my only worry with these headlights is that if smth goes bad. High beam or Low beam it seems like a royal pain to change.
Also if the DRL light or the signal LED goes bad you pretty much have a useless headlight since you cant simply change these out.
I love the way these look though and have gotten many positive comments about them. A guy in his c63 at the dealer even said: Hey we have the same lights dude, didnt even notice they were replicas.
3 car washes so far and 2 rainy days with 0 issues.
Good luck
Old 05-07-2014, 02:51 AM
  #114
Rasmussen52's Avatar
W205
Hi
Is this the same type of headlight, just with H7/H7 bulbs?
http://www.ebay.de/itm/Scheinwerfer-...item3a8b284851
Old 05-18-2014, 05:12 PM
  #115
JaredP's Avatar
2014 E63 AMG S
Can anyone who has done this install let me know how to unplug the headlight module? I've been yanking on the plug and cannot get it to come out.
Old 05-22-2014, 03:51 PM
  #116
2014 E350 4MATIC
Go to 4:50 and watch how he removes the plug. You have to use a pick or something with a fine point to pry up the tab that secures the plug to the assembly.
Old 05-27-2014, 10:33 AM
  #117
hellasmania219's Avatar
2009 C300, 2012 GLK350, 2012 C350C
I just upgraded to an HID pair of headlights on a W204 that had halogen stocks.
These include a white LED bar where the turn signals are.
They are also a bi-xenon setup with D1S, fully integrated with ballasts and self-contained in the headlight housing - no wires or ballasts hang out from the headlamp.
Video of locking/unlocking:
Pics: of DRL, C, and Led bar:
Old 05-27-2014, 10:40 AM
  #118
Clkboi's Avatar
CLS550 4Matic
Ok buddy you cant post these awesome headlights without telling us where you got them. Link ASAPPPPPP please
Old 05-27-2014, 10:41 AM
  #119
Clkboi's Avatar
CLS550 4Matic
W204 Headlamp Removal DIY (Abridged 5:00 Min Edit) - YouTube
i am assuming you figured this out already right? Sorry i wasnt able to reply to your PM just saw it
Old 05-27-2014, 01:06 PM
  #120
JaredP's Avatar
2014 E63 AMG S
Yup, I checked out the video and figured it out. The locking mechanism was a little confusing to figure out without actually removing the headlight. I was just splicing in for power to my illuminated star.
Also, hellasmania, could you go over which lights are illuminated in various situations? What is illuminated when unlocking, when low beams are on, and when high beams are on? The white bar is kind of cool.
Old 05-27-2014, 02:33 PM
  #121
I actually did not order this set from eBay. I will get and post contact info for supplier ASAP, as I only have an email address.
Functionality:
Daytime - Unlock and only turn signals flash orange. Lock and only turn signals flash orange.
Nighttime - Unlock and turn signals flash orange then fade on to white LED strips like in the Video, and C parking lights come on as well. Lock and the same occurs.
Driving - At night, C parking light, white LED bar, and headlights are illuminated
Old 05-27-2014, 07:19 PM
  #122
NibblerRx's Avatar
2013 C250
I just ordered a set of these headlights with the 6000k bulbs from fishcake321. Looking forward to this nice upgrade for my car!
Old 05-27-2014, 08:47 PM
  #123
UCSD_C350's Avatar
2012 C350
I ordered these from fishcake also but noticed that another user, americanmotorparts, was selling them for around $320. The seller contacted me the day after and said there is a manufacturer recall on them right now for an unknown reason and had to cancel my purchase. Makes me kind of nervous but went ahead and ordered them anyways.
Any of the users having problems with them so far?
Old 05-27-2014, 09:25 PM
  #124
Super Moderator
MJ50's Avatar
bone stock E55 AMG
cool!
definitely on my modlist...
will eventually get one with HID pre-installed...
Old 05-28-2014, 02:57 AM
  #125
yacoub.alyacoub's Avatar
2012 C200 CGI AMG Sport,2011 SLK 200 Komprs R171 2000 Toyota Land Cruiser GXR, 2007 Jeep Wrangler JK
Functionality:
We're all waiting
This is a proper headlight
can you please show us more of it during night time high beam and low beam how do they look like? whats the different from the OEM except for the led strip at night?
also does it have the bulb ballast within the headlight assembly.
The best after marker headlight I've seen so far way better than those on ebay with a huge ugly C.
was it straight forward the connectors or does it need some modifications for the wiring.
Quick Reply: new LED Projector Headlight Pair
