Aussie C200cgi Build
W204 MY10 C200CGI
Hey guys,
Thought I would follow the trend and start posting updates as I play with my baby.
This is what it looks like now. I've only had it for a few weeks though...
I have fitted the Carlsson C-Tronic ECU unit and their high-flow intercooler (which looks and feels suspiciously like the CDI stock FMIC unit..
Performance gains are awesome and with not much coaxing she goes sideways through any corner.
W204 MY10 C200CGI
Just bought these bad boys, I seem to have a Carlsson theme going....:
Planning to black out the headlights, maybe this weekend
2010 C200 CGI
Please elaborate, if that's the case then maybe I should just order the CDI version how were you able to know it's similar to a CDI unit? Stock for stock would diesel versions need a larger FMIC?
W204 MY10 C200CGI
It's been two years since I last saw a CDI intercooler in the flesh, so don't take my word for it, but I am pretty sure that's what Carlsson has provided me. That said, their price for the unit is cheaper than MBAu will sell me a CDI unit anyway.
Here is the new Carlsson unit next to the OEM C200cgi one:
I'll snap some pics of the ECU piggyback over the weekend
2010 C200 CGI
The end tank design looks like it bottlenecks compared to the CGi unit. I just checked the OEM FMIC between CGI and CDI, here are the measurements.
CGI
Length: 626 mm
Width: 127 mm
Depth: 62 mm
CDI
Length: 625 mm
Width: 128 mm
Depth: 62 mm
These measurements don't seem that radical that it would do much difference if the Carlsson unit is in fact a CDi unit would it?
Edit, After checking again as the CDi measurements I posted above are from a C200 CDi, it seems the C220 CDi measurements would match what you posted better. With that taller face I could see it being somewhat more efficient.
220 CDi
Length: 625 mm
Width: 143 mm
Depth: 62 mm
CGI
Length: 626 mm
Width: 127 mm
Depth: 62 mm
CDI
Length: 625 mm
Width: 128 mm
Depth: 62 mm
220 CDi
Length: 625 mm
Width: 143 mm
Depth: 62 mm
2010 C-Class 200CDI
Knightmare69, could you please post the intercooler sizes that are on the V6 CDI's?(eg. C300CDI, C320CDI, C350CDI).
I am intereseted in changing the intercooler on my C200CDI and as far as I know the biggest intercooler I can install is the one from the C220CDI. The C250CDI is a biturbo so it's intercooler can't fit on my car, but what about the bigger diesels?
W204 MY10 C200CGI
Dynos are really for fine tuning in my opinion.
I might dyno it in the future but, seeing as we can't really play with the tune, I'm not really bothered. After all, it's only going to give me an arbitrary figure that I won't be able to change too much.
W204 MY10 C200CGI
Carlsson Callsica CPI/IGs 18x9.5 and 18x8.5.
The offset is only 31 so need to get them machined before they become a permanent fixture.
W204 MY10 C200CGI
didn't get time to do the headlights but I did the grill. No plasti-dip. I deconstructed the grill and sanded it back, then primer, gloss black and clear coat. DIY thread to follow.
Before:
After:
I was under time constraints to reassemble so I had to put it back on the car tacky. As a result, right below the star are two chunks of missing paint. I will be able to fix those on the car so stay tuned for a DIY on that also (I guess my mistake will be everyone elses boon )
Before:
After:
2010 C200 CGI
Also AusMB87, can you let us know if you experience any lag with the larger FMIC? From what I understand, a larger intercooler but smallish turbo usually creates room for lag, even with the tune it's more the size of the turbo that will affect how it works with the intercooler.
W204 MY10 C200CGI
It will prevent turbo lag.
The main source of turbo lag is volume within the intake between the turbo and the manifold. While you want a large enough diameter to prevent restriction, if you have too much empty space the lag will build up. Additionally, the larger the area, the slower the air flows through it (see venturi effect).
Also, note that the carlsson unit flares out much larger into the wider core.
It's all about balance, especially when we are talking about such a small turbo with such a long distance to the intake manifold. I can tell you that there is a noticeable difference between the tow units, as felt in the drivers seat.
W204 MY10 C200CGI
sizes are:
front - 18x8.5 ET31
rear - 18x9.5 ET35
I know the rear will fit with some stretched rubber but the fronts, well, that's pretty out there.
I will fit them with stretched rubber and see what happens. I think it will be ok until I lower it, then I think I'll need to have the offset machined down a bit
W204 MY10 C200CGI
Just picked up some Carlsson lowering springs for $200 shipped. Also ordered the 5mm rear shims. I will probably look at shaving the front shims to suit.
W204 MY10 C200CGI
had a bit of a play with the car this weekend. Replaced the lower grill slats with an inset mesh, stripped and painted the peeling console trim around the cup holders and debadged.
Here is a progress shot
before shot of console trim:
Finished console trim:
and grill (original in post above):
Before:
After:
Before:
After:
W204 MY10 C200CGI
W204 MY10 C200CGI
So driving to work this morning and suddenly the car is revving like crazy and going nowhere. It was still accelerating slowly so I don't think it was slipping clutch packs - felt more like the TC. Turned it off and on again at the lights - problem fixed.
I will have to get it onto a STAR machine and see what codes were thrown.....
W204 MY10 C200CGI
Rang the dealer who has been servicing this car - never had a transmission service so that's where I will be starting. 120,000km on original fluid, GAH! This is why I don't work for them any more.
Anyway, to make myself feel better, here are some pics of the freshly debadged rear end. Looks so much wider without the chrome all over it
