Check Oil at Next Gas station
Old 09-02-2014, 08:48 AM
cmvazquez103's Avatar
C 280
Thanks Stiggs for telling me to post in C Class. Subtle
The week before I had schedule an oil change I started getting this message after driving for a few miles. I checked the oil and it was between the level of reasonableness stated in owners manual. I changed the oil this weekend and as soon as I left the garage the message popped up again. Obviously the oil is at the needed level since it was just filled and checked. What would cause that?
I drive a 2006 C280.
Old 09-02-2014, 05:14 PM
AusMB87's Avatar
W204 MY10 C200CGI
Maybe a dodgy oil level sensor
Old 09-02-2014, 06:07 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
A MY2006 would be a W203 forum question
Old 09-02-2014, 07:14 PM
AusMB87's Avatar
W204 MY10 C200CGI
good point. Still, shares a w204 engine so negligible difference
Old 09-02-2014, 09:14 PM
steven1888's Avatar
2008 c350 sport
I would think who ever did the oil change, put in the same amount they took out. This happen to me and all it needed was some extra oil. Get Mobil 1 0w-40 229.5 oil which is recommended for mercedes.
Old 09-03-2014, 08:15 AM
ralawren's Avatar
2017 GLC300 / 2021 C300
Make sure it isn't overfilled. Just had this on my other car. The dealer had maxed out the replacement and ended up having to drain it all back out while at temperature and then put in the correct amount.
Since the problem started before the oil change this is probably just an outside chance. But you never know. Cheaper than changing the sensor.
Old 09-08-2014, 03:50 PM
C 280
check oil at next gas station
Thanks for the replies. where is the oil level sensor located? Hard to replace?
Quick Reply: Check Oil at Next Gas station
