Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Maintenance
- Mercedes-Benz C-Class: What is ESP, and How Do I Turn It Off?
Step by step instructions for do-it-yourself repairs
ESP CURRENTLY UNAVAILABLE PROBLEM
Benz C220 cdi
I have bought a C220 Cdi 2007 model w204 and when I received it everything was smooth for a couple of days until the ESP lid came up with check engine signal on the display. I have brought it to a Mercedes engineering shop and the computer read two error codes P0087 and P0088.
Those are "fuel rail system pressure too low and too high". I have try to reset steering wheel angle sensor by turning the steering wheel 5 times from left to right to the end stops but with no luck. Still the same errors.
When I switch off and on the car 4 times the esp unavailable signal disappears but after a wile it's coming back. It is very annoying because every time this happens the car slow down and the throttle has limited effect on the car.
Any idea how to fix this?
