Clunk In The Front End
I took my '12 250 in for service due to a clunk in the front end when backing up and turning, which to my suprise, they were able to reporoduce by backing up in a figure eight pattern. Here is what was replaced:
Found LI33.15-P-047471 applicable to this vehicle.
my question is what does this last number indicate? what is an Elastomeric cup, and what is an Hydro mount?
- 4 211-333-06-97 ELASTOMERIC CUP
- 2 204-333-11-14 HYDROMOUNT
- 4 000000-003281 NUT
- 331426 BUSHINGS ON BOTH STRUT RODS REPLACE
The service campaign is probably correct.
I wonder if others had had this issue as well? for there to be a campaign it sounds like it may be a common issue.
Anybody else hearing a clunk or other noise while backing up with the wheel turned, or out of a driveway?
I have the same issue 2013 c250. Backing up from my drive way I hear the clunking noise from front passenger side. Just dropped off my car at the dealer 2 days ago. No news as of yet. Plus I've been having weird issue with fluctuating rpm needle.
Good luck
2013 c300 4matic clunk noise also
I will be taking it to the dealership today! Thank you for this great post. Will see if they can find it as well and fix. If not will give them this info and let you all know if resolved
Common problem since w203 era...
https://mbworld.org/forums/attachmen...trol-20arm.jpg
Those dam bushings crack and leak fluid after about 30k miles.
Elastomeric cups are just some rubber cups to protect the bushings from elements.
They only replaced 2 upper control arm bushings since it's what usually goes bad.
