Headlights are not plug and play!!!!
I own a 2010 and I've been doing research on upgrading to the 2012 style. I found out that the harness looks the same, but the connections inside the plugs are in different positions. I know that I will need a hood and I want a front bumper. I am sharing this for those who are thinking that the conversion is plug and play.... its not.
I own a 2009, and converted to 2012 LCI. I paid almost $400 to have headlights professionally wired and installed. I know I could have done it myself but I wanted to make sure it went as smoothly as possible, with professional work.
User romeo291 did it himself, and I believe there is help somewhere on this forum regarding wiring diagrams.
You will have to buy the wires for the headlight pins to custom arrange them, they were $7 each from my nearby dealership. I had it setup so that the C led is lit when the engine is on.
I had a relay installed too.
good luck.
good luck.
good luck.
good luck.
But from what little I did see, and from the questions I was able to ask, I believe the custom wiring was entirely on the car harness side(male). I will try to ask the tech who worked on my car questions.
Any other questions you guys have for the tech that did the job? I will be contacting them within a few days to try to answer these questions. Might as well help the community if I paid for it.
