08 C300 EIS THEN ESL
So my car is having the famous won't start issue. Everything turns on fine on the dash and radio, but it wouldn't start. I had it towed to my local dealership after talking about the EIS vs steering lock prices and hoping its the cheaper one that's the problem. He called and told me it's the EIS and not steering wheel that's messed up and after a 15% discount, it will cost me around $1300 which is about $400 more than the estimate. I call today to check the status on the parts. I was told that the EIS was replaced and the car turns on fine, but they can't get the steering wheel to unlock and the car is giving a code for the steering lock to be replaced. He said it was only the 2nd time he's seen that both needed to be replaced, but I don't get it.
I would think that you would test both parts to see which one was the issue and tell me both need replacement from the beginning since I was telling them either one can be the issue after all the research I did. I find it odd that he said when they intially diagnosed it, they were getting a code for EIS replacement, but now they are getting a code for ESL replacement. I talked to a friend who knows a lot about cars and he's wondering if they misdiagnosed initially or broke the ESL while replacing EIS. What do you guys think? I feel like I'm getting ripped off. Could the steering lock issue only be discovered after the EIS was replaced or should they have been able to tell me from the beginning that both were messed up?
TIA
rani
TIA
rani
Hi Rani,
It's unfortunate but the dealerships are trained to replace components at the customer's expense. There is very little knowledge in the market when it comes to these components.
The issue is your ESL which is possible to be repaired. My company is currently in the process of becoming a Sponsor on this forum so I can post in the technical services area. We intend to expand significantly given the demand and the prices customers are faced with spending.
All the best.
Ronnie
www.euroluxuryauto.com
All the best.
Ronnie
Rani
2008 Mercedes Benz C300 4matic Sport
Hi Rani,
All the best.
Ronnie
All the best.
Ronnie
