Intermittent SRS left front displays along w/ red airbag light
Ok, today was the final day where the SRS Left Front Malfunction Service Required is displayed along w/ red air bag icon made it a full time malfunction.
Confirm culprit,,,, driver side seat belt female end attached to drivers seat both wires finally separated from wear of movement when I reached over to inspect underside of belt clicker the twin wire finally snapped off making it a full time light display, we all have done the research on this problem and sure enough my number was up,, in final resolution,, remove drivers seat detach female belt buckle from seat and bench solder twin wire connector as appose to spending $100.00 on new one? 1 hr fix easy easy,,,,, signing off,,,,,Master tech Steve Denney,,,
