help-need to re-sync key fob for 2012 c250
Old 08-30-2015, 10:52 PM
ratbuntir's Avatar
I just purchased a 2012 c250 with keyless go and the spare key was not working according to the prior owner due to a need to change the battery. I replaced the battery yesterday but it does not work at all, does any one know how to re-sync or re-program the key fob without going to the stealer?
Old 09-01-2015, 07:16 AM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
You just got snookered(cheated) by the seller---need a new 3 dollar battery,wada joke----if your new battery does not work then you either have a bad key or an issue with the central locking system, both of which can be solved when you ask the seller to fix the problem!!
Quick Reply: help-need to re-sync key fob for 2012 c250
