C350 4matic extreme vibration
2019 GLE 350, 2020 C63s Cabriolet, 2021 AMG GT R
So, I have a Mercedes C350 4matic that has always driven beautifully but last week it started vibrating in the back when I accelerated a bit at highway speeds. If just gunned down on the accelerator it would not vibrate.
I took it to Mercedes and was told that there was a grinding sound in my rear differential and that it needed to be replaced and was quoted $6k for it. I got used differential from a c350 4matic that only had 10k on and had it installed, since that was being done I also had the Transmission fluid changed as well. When I picked up the car everything was ok, the car drove fine but 3 days later the problem came back and was a lot worse.
This time when I drive it starts to vibrate even at low speeds and when I get to some speeds and play with the accelerator a bit I can find a spot that the vibration stops completely, but when I accelerate or decelerate it comes back. Also, I tried shifting the transmission to neutral while the vibration was happening and when I did that vibration continued.
I have so far spent more then 3k without fixing the problem.
Any help would be appreciated.
2012 Mercedes C250
In addition to what has been checked, I would have the drive shaft(s) checked. An out-of-balance drive shaft (they spin at higher RPM than the tires) will wreak havoc with drivability.
I am lucky that I have my other car and my wife has her but, I really hope to get my c350 back as I don't want to drive 45min to work and back with the SLS, the miles will add up pretty quick!
After reading that is what I am thinking as well. The vibration is only happening when the wheels has pressure from the ground, when on the lift no vibrations. I am having the car brought back to my car age and will drop the tranny down and do a full inspection. I was hoping to get this done by garage because I just don't have the time, but now seems I will have to make time to do it myself.
I will let you guys know.
if yours is rebuildable should be around 700.00 dollars .
if not over 6.000 dollars.
So today I finally got my extreme vibration fixed. I ended up having to take some time off and took upon myself to take care of the issue. I dropped my tranny (took me about 4 hrs of pain in the *** work) and found that the transfer case was shot to ****. I did a complete rebuild of it, ended up costing me about $250 bucks all together. I got the parts from a friend who works at a local transmission shop here in Montreal.
When I took off the transfer case there was metal shaving everywhere and looked like grounded coffee. After rebuilding everything, cracked open the transmission as well to make sure everything was ok, I was concerned that it was affected in some way. After cracking transmission open everything looked pretty clean, clutches and gears were all in very good condition.
I put transmission back together and took to a friends shop who has a dynamometer to check it out and thank god it was all perfect. Finished putting the tranny back in the car (another pain in the *** but this time had a friend to help) took for a test drive and the car was smooth.
